05-30-2015, 08:26 AM   #1
Suggestions for cleaning a dust spot
I seem to have a dust spot on, I think, my focusing screen. It shows up no matter what lens I use, but does NOT show up in any photos or live view. I should just leave it but it is pretty large and distracting and I worry about it moving around. Is there any easy way I can clean it or should I take it somewhere?
05-30-2015, 09:17 AM   #2
jatrax's Avatar
Use a rocket blower to try and dislodge it. But if it is on the focusing screen then it is an annoyance only. And often you end up just living with it.
05-30-2015, 09:50 AM   #3
fwcetus's Avatar
Yes. If it's on the bottom of the focus screen (i.e., inside the mirror chamber), maybe all it needs is just some upwardly aimed air (?).
05-30-2015, 10:29 AM   #4
Tjompen1968's Avatar
It is possible to remove the screen but if you touch it you will a fingerprint that will haunt you forever or a scratch that will enoy you. It is very fragile and made of plastic, not glass as I thought cleaning it with alcohol and got a melted focusing screen as a thank you. A new one was bought...
Blowing hard into the opening may cause dust to find it´s way up into the prism chamber so blow gently when cleaning.
05-30-2015, 11:18 AM   #5
Use a tweezer to remove the focussing screen and the hold it on the edges between your thumb and for finger, make sure you don't touch the face.
05-30-2015, 12:20 PM   #6
Dust is most likely on the bottom of the screen. Jet blower is the way to go.
05-30-2015, 02:37 PM   #7
Not got spots but do appear to have a few hairs on this screen - any pointers to more specific info on how to access / remove the screen to clean it?
05-30-2015, 03:02 PM   #8
jatrax's Avatar
QuoteOriginally posted by jeallen01 Quote
Start with a rocket blower. Remove the lens and holding the camera so that the opening is down gently blow into the focusing screen area. Most times that is all it takes.
Removing the screen to clean is NOT recommended unless all other efforts have failed. The screen is very soft and easily damaged. Getting it back in and aligned properly is not all that hard but it is fiddly and not usually necessary to clean dust from the screen.
05-30-2015, 11:59 PM   #9
Thanks - I'll remember that when I get around to the cleaning.
dslr, dust, k-3, k3, pentax k-3, spot
out damned spot! sensor cleaning and keeping it that way skierd Troubleshooting and Beginner Help 12 09-30-2014 07:13 PM
Sensor Spot Help/Cleaning Marcus_H Troubleshooting and Beginner Help 5 06-28-2014 07:01 AM
Sensor cleaning suggestions... Knock Pentax DSLR Discussion 8 07-20-2013 11:46 PM
dust spot, in view finder LFLee Pentax DSLR Discussion 4 06-06-2011 10:12 AM
Stubborin Dust spot arbutusq Pentax DSLR Discussion 3 02-13-2007 09:33 PM
All times are GMT -7. The time now is 03:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
