Originally posted by ScooterMaxi Jim Its primarily an issue with fast lenses set at relatively wide apertures. You can also run into it when you're using ultra-wides at the f-stops close to wide open. These UWA primes and zooms can have huge variations in focus distance as you move away from the center. The Tamron 17-50 f/2.8 is quite famous for the field curvature problem (on a lens that is otherwise excellent optically). From a practical standpoint, it isn't going to spoil many shots. It is enough of a problem, that I get a bit nervous when I shift - rather than do it right in the first place. If I'm nervous, then I just don't perform to my best on a shoot. So, a good part of the concern is a matter of confidence - based on a good understanding of how to shoot the right way.
That's somewhat what I expected. I haven't noticed any issues with my 18-135, but the widest aperture is F/3.5. I also have a 70-300 f/4-5.6, but that wouldn't fall under wide-angle or wide aperture, so I haven't seen it there either. I'll have to keep this in mind when the 17-50 F/2.8 makes its way from my wishlist into my camera bag though.
All of my other lenses are manual focus primes and wide zooms. I don't use the camera focus points but sometimes I focus and recompose. I'm still getting used to focusing with the standard focusing screen though, so if I didn't nail focus I've been chalking it up to poor lighting and the 160 lb problem behind the viewfinder.
