Originally posted by stevebrot ROFL! Sorry, not meaning to be disrespectful. It would be nice, but ...
Don't worry, no offense taken. I put the words "dream of" a firmware fix to indicate I'm quite aware of the likelihood of this possibility...
However, the change in behavior between the K-5/K-01 and the K-3 does indicate that this is an area where some code churn is happening...
Originally posted by vonBaloney I only have the K-5 to test -- changing the aperture does nothing at all to the display (as you know). However, changing the EV comp will in-fact darken or brighten the screen as you do so. Looks like the effect is restricted to the -2 to +2 range. Anything more extreme (it goes to -/+ 5) doesn't do anything.
This is very interesting. I will go back to test this on the K-01 tonight. If the K-01 does as the K-5 (quite probable), it means I could possibly use this to *brighten* the K-01 display using the EV comp, and then under the circumstances where I'm having problems with the K-3, I'd have, theoretically, a 4 eV brighter display on the K-01 (since the K-3 stupidly dims it by 2 eV and I can boost it by 2 eV on the K-01). This might actually make it worth my while to go back to the K-01 and its lower resolution sensor...! (EDIT: It occurs to me I could also use EV comp on the K-01 to brighten the display when shooting with reversed lenses... Nice!)
Originally posted by Stone G. One other thing that you might(?) contemplate to try is to press the AE-L button before you stop down.
Intriguing option, as Steve said. I can't test this right now, but as I stop down, won't the shutter time increase in such a manner that I'll always get a full exposure's worth of natural light in the total exposure? Thus, even discounting possible camera movement issues, won't adding flash will always mean the shot will be over-exposed? The only exception I can see to that is when the subject is in near darkness and natural light only affects the distant background, so that if you were really shooting without flash, you'd get an exposed background with a black subject. Then as you add the flash, you'd get the flash lighting the subject only, and natural light lighting the background only... Might be worth a try...?
Originally posted by vonBaloney I'm wondering how the FluCard mirroring works in this regard -- if you are using a phone or tablet as your liveview screen, does it go dark? And can you just pump up the screen brightness on your device?
Haha. It
would be interesting to know how the flucard liveview behaves in this regard, if only theoretically for me. Both because I don't have a flucard to test with, but mostly because then I'd need to be a two-man outfit! One person to hold the camera and focus by moving the camera body, and another person to trigger the shot on the remote device.
Quote: (Does just setting the screen on the camera to very bright help at all?)
That was one of the first adjustments I did when I got the camera, as I'd also done that on the K-01. I'm sure it helps, but my "corner cases" (where I miss a shot because of the dimming) already have that factor rolled in...
BTW, does the camera actually know when a fully manual (ie single pin) external manual flash (or flash trigger) is installed in the hotshoe? If so, (and to dream a little) it might be reasonable to send a message into Ricoh asking for a FW update with "no liveview exposure preview when using onboard or external flash"...?
