Hi all,
So has anyone witnessed the following behavior?
- Use an A-series or more recent lens;
- set the camera to M-mode and turn on Liveview;
- dial in a proper exposure using a fairly open aperture;
- now start closing the aperture using the in-body aperture control (
not the aperture ring on the lens - if your lens has one it should be set to "A");
- you should see that as the aperture setting increases, the LCD gets progressively dimmer and dimmer, to about -2 eV, from which point onwards the brightness remains steady.
I just tested this also on my K-01 and it does
not behave the same way as my K-3. Instead, on the K-01 the LCD's brightness stays the same regardless of how underexposed the camera thinks the shot will be once the shot is taken.
This behavior of the K-3 is very annoying! I shoot a lot of macro with manual flash in M-mode and with Liveview. Since the camera has no way of knowing the flash power, it thinks the shot will be quite underexposed,
and dims the LCD, as described above. So, I'm shooting with an artificially, and quite unnecessarily dimmed LCD! Under some circumstances, that's the difference between getting and not getting the shot.
If I'm using a lens with an aperture ring, a workaround is to use the aperture ring to set the shot's aperture rather than use in-body aperture control. This is much less convenient, but at least when I do that, the LCD display remains at normal brightness even if the camera foolishly thinks the shot will be underexposed. But if I'm using a lens without an aperture ring, then I think I'm up the proverbial creek.
So, what do you think? Is there a setting that will turn this off? Is it a bug? I don't think it's a feature, but you might?
I'm running FW1.11.
