06-23-2015, 05:34 AM   #1
unable to display image on back display
Stareted to have this problem recently. after taking multiple photo's and wanting to view tham afterward it gives a message on the rear display of Image to large to be displayed. the Camera is running with 2 X 32 GB card. It is recording the Raw + Jpeg option. After reading a number of forums it seem to suggest that this may be a lens issue. But after using a couple of differant Lenses the fault still happens intermittently. I have just upgraded the firmware to 1.21 to see if it may get over the issue. I think i may have found the issue but would like someone else to conform if possible.
When taking multiple shots in quick succesion this may be causing the problem as i may be taking them as the camera is still writing the image to the Memory card. Any one come accross the error please.?
06-23-2015, 07:05 AM   #2
Ole
Ole's Avatar
Could there be images left on the card that were shot with another camera?
06-23-2015, 07:55 AM   #3
unable to display images
the cards had both been freshly formated before use. as i was not using any bracketing or multiple frame capture at the time. It was just clicking away at a sports event.
06-23-2015, 01:44 PM   #4
slip's Avatar
Never had this problem. Try different modes example raw or jpeg but not together to see if the error doesn't come up again
Good luck
Randy
06-24-2015, 02:48 AM   #5
QuoteOriginally posted by slip Quote
Good luck
Randy
thanks Randy for the advice i will give a try. if the error stops then Pentax/Ricoh should update the firmware to either disable the option or fix it.
camera, card, display, display image, dslr, image, issue, k-3, k3, pentax k-3
Camera cannot display this image TeddyVerona Visitors' Center 5 06-12-2014 11:23 AM
Raw Image Display PENFRED Troubleshooting and Beginner Help 11 03-18-2013 05:28 PM
Pentax K-5 will display image in to laptop? antoruiz Pentax DSLR Discussion 6 05-24-2012 04:43 PM
Image Resolution for Display calicojack Troubleshooting and Beginner Help 9 10-25-2009 11:21 AM
Image display problem Magpie Pentax Compact Cameras 4 04-05-2009 06:37 PM
All times are GMT -7. The time now is 06:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
