Originally posted by slip Edward: did you run any shots with a narrow DOF to see if the tracking is accurate? It seems like the shot you posted has a very wide DOF which helps keeping the subject in focus
Thanks
Randy
Hi Randy, the shots that the tracking worked perfectly on were shot at F8. The shot below in which not 1 photo out of 10 was sharp except maybe the first one were shot at F6.3. So I really don't think a 1/3 stop difference in DOF has any bearing, and you can tell by this photo that there is a sharp plane of focus, it's just 15 feet behind Chloe the Wonder Puppy.
I guess to truly test the system these should be shot at 200mm and F2.8. Maybe next time...
---------- Post added 07-07-15 at 03:38 PM ----------
Originally posted by ScooterMaxi Jim Either way, it tracked nicely (responding to Flores). I do recall a review somewhere with a bicyclist moving toward the camera where the tracking was similar to what you showed. I have no idea if that one was a situation where the AF was re-pressed, but it seems unlikely given the speed of the rider nearing the camera.
I guess to really test all this I need to whip out the 200mm and shoot at 2.8. I only have the Tamron 70-200 and it's not bad, but I'd love to test this with the DC Pentax 70-200, that would only be fair if we were going to make any comparison's to Canikon.
I just have this suspicion that if you put a Tamron 70-200 screw drive on a Nikon D7200 or Canon 7DII, you would probably end up with similar performance to the Pentax.
