07-03-2015, 10:14 AM   #1
dcpropilot's Avatar
Catch in Focus
Hi,
I have an 8mm and 14mm Rokinon, and am having trouble setting up the catch in focus on the my K-3. On my K-30 I was able to set it up where I would hold the shutter button down, rotate the focus ring and the when the subject was in focus the camera would automatically take the shot. On my K-3, it takes the shot right immediately when pressing the shutter button, even when the subject is not even close to being in focus. Maybe I have the settings wrong? Any suggestions?
Thanks!
07-03-2015, 10:35 AM   #2
Your focus mode needs to be AF.S
In the custom menu setting #15 needs to be focus priority and #25 set to on.
Hopefully that helps. If you have done that, then I don't know.
07-03-2015, 12:03 PM   #3
Also check in the Capture menu, 'Button Customization' (Page 4 of that menu) that you have set the AF Button to 'Cancel AF'. CIF and the AF-button don'twork together.
07-03-2015, 01:14 PM - 1 Like   #4
dcpropilot's Avatar
I changed AF to AF.S (it was on AF.A) and I changed AF Button to 'Cancel AF' in the button customization menu. It now works. Thank you!!!
07-03-2015, 01:41 PM   #5
wtlwdwgn's Avatar
If you disable shutter button AF you can use the AF back button to focus. Just hold the AF button down until you get focus confirmation and then press the shutter button. Works in both AF.S and AF.C. Just my $.0.02.
07-03-2015, 02:06 PM   #6
QuoteOriginally posted by wtlwdwgn Quote
True - still, for me CIF has some virtues of its own:
1) The camera is faster than me (I can only speak for myself) and the 'instant' release is beneficial for both handheld macro and photos of moving subjects with MF lenses.
2) With CIF you can make an efficient photo-trap - using either MF-lenses or lenses with an AF/MF switch - merely with a cheap, wired relase and with the camera in continuous shooting mode.
07-03-2015, 03:27 PM   #7
QuoteOriginally posted by dcpropilot Quote
Glad to hear you got it working.
07-04-2015, 10:30 PM   #8
ScooterMaxi Jim's Avatar
Those are both fine lenses (I have both), but I wouldn't expect great results in CIF with the UWAs. It seems my best focusing luck with the 8mm especially is using LV magnification. Using the distance scale on the 8mm (corrected for focus past infinity) also seems to work better than the viewfinder.
07-05-2015, 04:02 AM   #9
dcpropilot's Avatar
QuoteOriginally posted by ScooterMaxi Jim Quote
Thanks! I have to try this technique!
08-05-2015, 01:41 AM   #10
shiner's Avatar
So, you can't use catch in focus as a trap focus with a AF lens- like a DA55-300, for instance?
08-05-2015, 01:25 PM   #11
Otis Memorial Pentaxian
QuoteOriginally posted by shiner Quote
Only those with an on-lens switch to turn it AF off.
08-05-2015, 06:40 PM   #12
shiner's Avatar
That's too bad. With the camera on manual focus and M mode, it doesn't try to focus anyway, wonder why they can't make this work with a af lens? Bummer.
08-05-2015, 10:32 PM   #13
...wonder why they can't make this work with a af lens?
A little time with the feature and you will understand why. Catch-in-focus is the fail-over behavior of when AF is turned on with AF-S as the mode, but the lens cannot be focused except by hand.
03-16-2017, 08:46 AM   #14
panonski's Avatar
Hi,
Thanks!
Little bump on this thread,
I've searched for it, because I'm also one of them who fail to turn on "catch in focus" function to work. But then I find this thread, and my problem is solved. BUT, I have also one more question here - IS THIS MODE WORK IN LIVE VIEW ?
Seems it's reserved only for OVF focus confirmation, and operate. When I switch to L.V. and full pressed shooter button, camera shoot instantly, regardless that is, first of all subject out of focus at all, and secondly,
that I'm set in menu for AF-S - Focus, over Relase Priority...
Is this true with LV mode ? Or I'm getting something wrong here ...
03-16-2017, 10:28 AM   #15
QuoteOriginally posted by panonski Quote
This question came up on another thread and apparently it depends on camera and firmware level. On my K-3 (firmware v1.11), CIF works in live view, but only with lenses having conductive bases and I posted that information. Another user decided to try a firmware update to v1.30 on their K-3 and reported that CIF worked with both conductive and non-conductive lenses with that firmware.
I hope this helps.
button, catch, dslr, focus, k-3, k3, pentax k-3, shot, shutter, subject
Catch in Focus K-3 problem TCerbo Troubleshooting and Beginner Help 27 10-08-2018 02:19 AM
Catch-In Focus with Takumar [135/3.5] lenses on K-5II? malenisjaj Troubleshooting and Beginner Help 5 01-15-2015 11:10 AM
Catch in focus help Halftufish Troubleshooting and Beginner Help 6 03-31-2013 03:27 PM
Catch in Focus Battery life clippy3 Pentax DSLR Discussion 5 11-17-2010 07:42 PM
All times are GMT -7. The time now is 12:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
