Originally posted by csa There lies the problem, when I dbl-click the file, I get a message that (Foxit Reader or IE, etc.) "does not support this file format". I apologize to everyone about not knowing more about files, etc., but I simply do not.
Hi Carol
Just extract the .bin file. That's all you need. I've just checked the ZIP file from the Ricoh Japan site, and there's no read-me file in the ZIP file, only the .bin file. And, it's only the .bin file you need.
It's a minimum 32 MB card, not GB, so no problem there.
Updating Procedure
Provide a formatted SD memory card for the update software.
The download file is self-extracting. The following file is extracted.
•Fwdc220b.bin: This is the updated firmware.
Copy the above Firmware file [fwdc220b.bin] to the root directory in the SD card.
If your computer does not have a card slot, you can copy the firmware update file by inserting the SD card into your camera and then connecting the camera directly to your computer.
Insert the D-LI90 battery into the camera and confirm the battery is full by battery level indicator then turn the camera off.
Insert the update SD card (prepared in step 1) into the camera (slot 1) and close card cover.
Turn the camera power on while pressing the MENU button.
"Updates the camera firmware" appears in the LCD monitor.
Ver: 1.00/1.01/1.02/1.03 /1.10 / 1.11/1.20→1.21 will be displayed.
Press the four-way controller to select "Start" and press the "OK" button.
"NOW LOADING" appears on the LCD monitor and updating starts.
Please do not under any circumstances switch off the power before the update is completed.
When update is completed, the "COMPLETE" will be displayed at the left bottom of the LCD monitor, then turn the camera off.
Remove the update SD card from the camera.
I've carried out the update procudure with every update for my K-5 and have not had any issues. But, make sure you use a good SD card and a good and fully charged battery. Of course, if you're not confident to do it, then don't - but it's really easy, so you should not have any issues.
Coincidentially - I presume you've not done the updates for your K10 either? (There's seperate update files for each camera model - don't mix them up!)
