12-13-2015, 02:44 AM   #1
Question to K3 owners about intervalometer.
I have the original K5 and would like to use the intervalometer in combination with the two second mirror up function. However, that doesn't seem to be possible.
Maybe it's my tripod that is to weak but I do get problems during astrophoto when using the intervalometer and aiming for the stars. Vibrations from the mirror sort of ruins the method of using the intervalometer for this kind of job.
Do the K3 have the same restriction?
12-13-2015, 06:46 AM   #2
If I knew what a intervalometer was I would answer you with a clear and concise solution.
12-13-2015, 06:56 AM   #3
Unregistered User
Guest
QuoteOriginally posted by Gimbal Quote
Yes it does.
12-13-2015, 07:26 AM   #4
Unfortunately, the Astrotracer function is a 1 shot deal.
If you want to do multiple shots (for stacking?), you will need a tracking mount such as an iOptron SkyTracker or similar and a wired programmable remote.
Remember, the camera sensor can only be moved a few degrees during an exposure - you have to move the entire camera to properly track an object over a long period of time.
12-13-2015, 09:02 AM   #5
QuoteOriginally posted by Tjompen1968 Quote
Yes it does.
Oh crap, but thanks for the answer.
---------- Post added 12-13-2015 at 05:12 PM ----------
QuoteOriginally posted by Hamiltom Quote
Yes, but in this case I used a wide angle lens and a 10sec exposure without the Astrotracer hoping that I would catch a trace from the Geminids meteor shower,
So with a 10sec exposure and the intervalometer set to 14 seconds and 40 shots I ended up with a lot of pictures, all with a slight vibration and no meteors. I'm ok with the lack of meteors, but I don't like the vibrations.
12-13-2015, 11:17 AM   #6
Turns out it might have something to do with SR. I tried it again but with SR off and the problem seems to be gone. Perhaps the K5 doesn't turn off SR automatically when using the intervalometer? Will have to do some more tests about that.
astrotracer, camera, dslr, exposure, intervalometer, k-3, k3, k3 owners, meteors, mirror, pentax k-3, question to k3, shots
Question to Pentax K-S1 owners – shutter vibration alex-virt Pentax K-S1 & K-S2 35 05-31-2018 06:32 PM
Comparison question for K3 owners Setter Dog Pentax K-3 & K-3 II 10 02-14-2015 04:13 PM
Question to Pentax 17-70 Owners phatio Pentax SLR Lens Discussion 8 09-09-2014 07:29 AM
DA* 16-50 owners, question about your aperture blades when open jotarou1 Pentax SLR Lens Discussion 6 06-25-2014 12:50 PM
For the K7 owners: question about mechanical sound within body Vinfer Pentax DSLR Discussion 12 07-27-2009 04:48 PM
All times are GMT -7. The time now is 01:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
