01-08-2016, 01:06 AM   #1
Does the K-3 provide enough power for the Rode VideoMic GO?
Hi everyone,
First post here, so I hope this is the right section of the forum:
I need a shotgun microphone for the K-3 and figured that the Rode VideoMic GO would be the best choice, considering my tasks and budget.
However, it needs 2.5V output on the audio socket while the K-3 seems to only provide 2.0V.
Does anyone have experience with this combination so far and if it's working? Or can you recommend an alternative in the same price/quality range?
Thanks for your help!
01-08-2016, 02:38 AM   #2
hcc
hcc's Avatar
I cannot comment on the Rode VideoMic GO.But I use the Rode VideoMic Pro shotgun. I posted my review at Rode VideoMic Pro shotgun reviews - Pentax Camera Accessory Review Database. The VideoMc Pro has its own 9V battery.
I shared my experience at; https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/275789...o-shotgun.html. In particular, I alert you that mounting the shotgun on the flash hotshoe might pck up some low frequency linked with the SR:
https://www.pentaxforums.com/forums/172-pentax-k-3/279013-sr-characteristic-s...uency-ies.html
Hope that the comments may help.
01-08-2016, 04:55 PM   #3
ScooterMaxi Jim's Avatar
The Opteka VM-200 is about the same price, 9v powered, so it provides plenty of input. They are well matched - and the Opteka pretty much matches the $200 Rode mic. The only downside is the weight - very heavy. If I was in your situation, I would also consider the Olympus DM-620 recorder with the Tresmic system. I use the older Olympus LS-7 (a slightly higher end recorder) and the results are very good on the K-3 (audio out - so I end up with discrete and camera recording). The Olympus PCM recorders in the $120-200 range are stellar.
05-16-2017, 09:45 PM   #4
richandfleur's Avatar
Good question re the K-3 and passive mics.
I'm considering the rode videomicro 🎤 and wonder if anyone has used the passive Rode mics like the go or videomicro successfully in the K-3?
dslr, k-3, k3, microphone, pentax k-3, rode, videomic
Experience with Rode VideoMic Pro shotgun hcc Pentax Camera and Field Accessories 6 11-11-2014 03:22 PM
added a Rode Videomic Pro... results are.... Wired Pentax K-3 & K-3 II 2 02-24-2014 05:58 AM
Rode Videomic Pro - Right Channel only mrtickles Troubleshooting and Beginner Help 2 12-22-2011 12:51 PM
First test K-7 with Rode Stereo VideoMic jogiba Video Recording and Processing 29 08-13-2010 05:20 AM
All times are GMT -7. The time now is 07:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
