Originally posted by Rob Shepter I'm supposing the metering is the same, or similar, between the two as I can't find any mention on Ricoh.com of any "fantastic new metering system" for the K3 over the K5II/IIs.
The K-3 metering chip is a 86,000 pixel RGB sensor; the K-5/K-5II metering chip meters a scene at a maximum of just 77 segments ... So the metering hardware is physically very different between the cameras, as is the metering software (and features).
If you ever want to see the difference, have a look at a K-5 and a K-3 image in EXIFTOOL, and you'll see data for
thousands of metering points in the K-3 file
, compared to a relatively tiny number of metering points for the K-5.
---------- Post added 2016-03-24 at 09:18 AM ----------
Originally posted by Rob Shepter Both cameras were set to centre spot metering.
Unless it was just for testing, one probably should not routinely use that mode. It only meters about 5% of a scene, from the dead centre, and is best used for special purposes. It also basically switches off the 'intelligence' of the K-5 or K-3 metering system, and gives the camera metering system very little information to work with in terms of scene lighting or colours.
