Originally posted by Echo Eric The two lenses I primarily use are a Pentax HD DA 16-85mm and a Tamron 70-200mm f/2.8 DI LD (IF) Macro
For my camera settings, currently I am using:
- The AF button on the back of the camera, not the half press focus
- AF.C - Continuous focus
- The center 9 points for focus tracking, making the center point my starting focus
- Action in AF.C focus is set to Focus priority, not shutter priority
- High priority (4) - for Hold AF status
I recently got the da* 60-250 f4, and I have been losing my mind over the same back focusing issues. After trying nearly every combination of auto focus setting and AF fine tune adjustments, I think I finally have the correct formula for shooting figure skating with my K-3 II.
First of all, I stop the lens down to f5.6 to give the focal plane a bit more wiggle room. I can't wait for the Pentax 70-200 2.8 to come out so I can gain that extra stop of aperture, but until then, I use around ISO 1600 which seems to produce a negligible amount of noise that is easily removable in ACR.
Next, af.c is fairly decent on this lens/body combination. Using 9 point focus will very often find the contrast in the background before the actual subject I am trying to shoot, so I have learned to use only the center point which has produced many more usable in-focus shots. I have my AF button on the back of the camera set to disable AF when pressed, thus I am able to center the subject to gain focus, then press the AF button and move the subject anywhere in the frame and still retain focus. I strongly recommend this method, in conjunction with the half-pressed shutter button for AF to quickly take shots as soon as the subject is moved to proper position.
I also have high priority af turned on, though I am really not sure how much this actually helps when using the single spot focusing.
This may or may not be relevant to you, but I have +4 AF fine tuning on just this lens. It seems to help with fast motion, but I think it may just be my copy of this lens.
I hope any of this helps you, I know how frustrating it is to find faults in either the expensive gear or the technique, but keep practicing and experimenting and most importantly - learning! Here are some pictures - the exif data should help better clarify some things I mentioned
