Originally posted by aleonx3 I faced the same dilemma before, and because I have so many photos (thousands) to process each time after a gig, I had thought about that before. I didn't like the previous versions of Silkypix (prior to 6). I just use the standard version which surprisingly is cheaper (currently on special price) than Photoshop elements and LR. I am a very happy user of Silkypix now, of course, YMMV.
Thanks again.
I will certainly consider Silkypix 6 once I go through the paces with what I presently have.
---------- Post added 02-20-16 at 07:27 PM ----------
Originally posted by jatrax I don't know if CS5 applies anything by default on import so I cannot help there. Lightroom is 'script' driven so on import it will apply automatically a set of adjustments if you want, which I do.
What I mean by develop for the sensor is simply forget everything you learned or did with your k-5 images. The K-3 is different, the sensor does not produce the same image as the k-5. If you develop a k-3 image the same as a k-5 image you will be disappointed. I am definitely not the only one to notice that. There were a lot of complaints initially as people used k-5 develop settings on k-3 images with poor results. Several initial reviews were very negative, I suspect because of this reason.
So, basically forget everything you know about developing an image and start over. K-3 sensor is different. My reaction, at first, was the same as NZ_Ross "what have I done". Seriously considered sending the k-3 back! But glad I did not, the image quality is there you just have to learn how the sensor reacts. Think of it as learning to develop a different brand of film. Things are mostly the same, but not completely and that gets you in trouble.
Well, I suppose this is like coming to a new system altogether.
I must have put at least 90,000 clicks with the K5 and I have been so used to it that it became "intuitive" .... automatic!
I also did some tweaking in the camera settings for Hi ISO NR: I've set it up to my taste in the "Custom" NR pull down sub-menu, after watching the video suggested by NZ_Ross - Ed from Photouniverse .
That should help.
---------- Post added 02-20-16 at 07:28 PM ----------
Originally posted by derekkite Falloff in quality. You will find that it is either stunningly sharp, clear and nice, or garbage, no in between.
Alright, and thanks again for the help.
---------- Post added 02-20-16 at 07:29 PM ----------
Originally posted by NZ_Ross Now I think about it - Ed from
Photouniverse did a big rant on how bad the K-3 image quality was when he first got it coming off a K-5.
Then he adjusted the default factory settings and seemed to end up happy enough with the image quality. From memory he also has a video on the settings he uses for a K-3 which is basically how I have my K-3 set up. Just do a search on K-3 on his Youtube site and you will find them. There might be some helpful stuff there for you.
Good thing!
Just viewed the video and applied some of the settings he suggested, especially as they relate to Hi ISO NR settings.
After a little tweaking, I'll go back out tomorrow and retest this K3 again.
Thanks for the help!
