04-07-2016, 02:03 PM   #16
Nicolas514's Avatar
QuoteOriginally posted by darylk Quote
Wishing you the best possible outcome!
Thanks Daryl!
04-07-2016, 02:09 PM   #17
MarkJerling's Avatar
QuoteOriginally posted by Nicolas514 Quote
I also had the 18-135 WR on the camera, so it should have been WR all around... DIdn't change the lense outside either.
I've shot in heavy rain with that combination and have never had a problem. So, I do wonder if there's some other issue perhaps?
04-07-2016, 03:29 PM   #18
FWIW, dry-cabinet's (or small dry-boxes with electric de-humidifiers) are a good investment, if you find yourself regularly shooting in damp environments, have to store your gear in humid places - or have to dry out some problem gear ...
04-07-2016, 10:27 PM   #19
QuoteOriginally posted by UserAccessDenied Quote
I'd say put a lens on, or at the very least the body cap if doing this!
Better still, take off the lens and drape tightly over the open mount a panty hose (nylon stocking or similar). Put the cam opening facing down in a small box and fill up the box with rice. Better than rice would be Desiccant. For this purpose I keep collecting over the years the small Desiccant satchels which are often supplied with certain food such as rice crackers. (Keep them unsaturated by microwaving them very briefly from time to time, often only needs a few seconds in the microwave)
Have you made sure the lens has not moved from the "A" setting ". Can happen unnoticed when changing lenses.
Cheers
04-11-2016, 03:00 AM   #20
Nicolas514's Avatar
The camera is in a rice box. How long should I wait before trying it again?
04-11-2016, 03:14 AM   #21
I'd stick the rice box on top of the fridge (where it's always nice and warm) and wait at least 3 days to a week.
04-11-2016, 06:24 AM   #22
Nicolas514's Avatar
QuoteOriginally posted by MarkJerling Quote
Thanks Mark!
04-14-2016, 12:42 PM   #23
Unregistered User
Guest
Have you removed the SD-card/cards and then turned it on?
04-14-2016, 01:42 PM   #24
Nicolas514's Avatar
QuoteOriginally posted by Tjompen1968 Quote
Yes I did!
04-14-2016, 08:01 PM   #25
My k5 got damaged this way this winter. Went to Cuba with the camera in bagages. The k5 was really cold when I got it back. Opened and changed lens and the hot wet air of Cuba got in. Got some random troubles. In the end metering wouldn't work anymore. It's in the repair shop right now.
Hope it goes better for you.
04-15-2016, 02:29 AM   #26
It should have started by now, guess it is smoked.
04-15-2016, 05:17 AM   #27
QuoteOriginally posted by niceshot Quote
No harm continuing to do the good things described above even if it has not yet started. It might just need more time.
If you have various alternates for the interchangeable bits: lenses, SD cards, battery, change them all one at a time to see if the difficulty is with one of those things, or how it is inserted.
Do you have face to face access to an old style camera shop which can do repairs. If so, take it to them and they may be able to give more advice.
04-15-2016, 04:07 PM   #28
QuoteOriginally posted by Finger Quote
850$ to fix a k5
I guess I'll keep my live view/manual k-5.
04-18-2016, 05:14 AM   #29
Nicolas514's Avatar
Took out the camera of the rice box today. No change... :'(
I will have to take it to a repair shop but I'm worried that here in Sweden it'll be outrageously expensive. I have a back up K5 back in Canada and now I'm wondering if I should use that one and put money aside for a K1. Sad day indeed.
04-18-2016, 05:35 AM   #30
Very disappointing!
buttons, camera, dslr, iceland, k-3, k3, loss, pentax k-3
Condensation inside lens - 18-50mm WR rob_k20d Pentax SLR Lens Discussion 25 02-19-2016 03:52 PM
Macro Condensation Tamia Post Your Photos! 11 03-01-2015 02:02 PM
condensation in nyc by winter, actual issue? zitounae Troubleshooting and Beginner Help 9 12-01-2014 01:27 AM
Swimming Pool Condensation Advice cpho Pentax SLR Lens Discussion 6 06-21-2014 03:37 PM
Condensation on lens Camera lucida Photographic Technique 5 10-21-2008 05:10 PM
All times are GMT -7. The time now is 02:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
