Originally posted by Nass My profoundly unscientific guess would be that firmware 1.21 changed your K3's exif output and that EXIFtool can't read it anymore
That is a reasonable guess!
Originally posted by bxf EXIFTool is showing (None)
Question...are you getting this result for out-of-camera JPEG, PEF, and/or DNG or have the files been processed by a tool?
Does PDCU 5 have similar fields without values? While Pentax has been known to change field mappings between models or add to the mappings/values, the fields and their mappings generally don't "go away" with firmware update, partially because doing so will create problems for Pentax software already deployed.
Which ExifTool version? The current release is v.10.14. If yours is lower than v9.96 you might want to update.
