Originally posted by tediscool310 Thanks for all the input, I've just ordered two of the Lexar 64GB cards from B&H, $18 each!
I tend to take a lot of photos while on trips (shooting in burst mode), and I don't want to mess with spare cards or transferring to PC if I can help it.
I have two 64's as well, shooting RAW + JPEG. They should last you quite a while.
Since you like shooting in burst mode you should test your cards before you trust them with your pictures. I had an issue with mine where I would have a card access error during prolonged bursts or continuous reads. (Here's a
previous post with more details if you're interested.)
To test your card you want the fastest write possible, so set your camera in manual exposure with a fixed ISO and fast shutter speed (1/100 or 1/1000 if you're somewhere bright), manual focus, high speed continuous, in camera lens corrections off, RAW + jpeg, single slot recording, and fire away for a nice long burst to put a heavy load on the card. (This way the camera spends the least time thinking so you'll be able to hit the max fps.) Then go to playback (full screen) and hold down the left or right directional button. It should be able to cycle through your pictures like an old silent movie until your thumb hurts.
Try this with each card in both slots and you should expose any shortcomings with your cards. (Single slot recording will give the fastest write speed, but you may want to try with dual slot recording too if that's what you'll be using.)
Before anybody says anything, yes, I understand this puts extra wear on your shutter / aperture and increases your shutter count. In my opinion, with a rating of 200,000 actuations I have plenty to spare. I'm currently around 60k and I'll probably upgrade to a new body before I hit 200k, so I'd rather nudge that number up a few hundred than have SD card issues when I'm out taking picture.
