Originally posted by JEstebanFC I believe is something with the light meter, the other day I was taking photos in Manual and the picture was perfect but the light measurement show me -3, I was using the center to measure, but the things is even if I move it the measurement was the same
If your meter is not responsive to light, then you have discovered the cause. If this is a recent purchase, you might consider contacting the seller. As for spot metering, I will assume you know what you are doing and are using that mode to place exposure.
