I had a few moments of frustration and embarassment this week using my K3ii. I was using it at work this week with a flash unit when two problems occurred at once neither of which I'd encountered before. Firstly, I couldn't activate the flash menu unless in LV. Secondly I couldn't move or re-centre the AF point. Frustratingly, it would self-correct for no apparent reason every now again. I need to add that I can operate this thing blindfolded - literally. I also have a fairly ingrained style and tend to use the same niche of functions as I'd imagine many of us do.
I was able to work around the problem, all the while building up theories about a new type of 'Pentax is doomed' fault, a colleague pranking me, or the possibility that I was simply losing the plot. Just picture a lot of cursing, button pushing and battery ejecting going on all at once.
Anyone with this model probably already knows the answer, but it took me until later that night to realize I was inadvertently toggling the lower RH button. I was made worse by the increasingly randomized button pushing going on.
If you own a K-3, place a mental sticky note for future reference.
Take from this what you will. My colleague got a lot out of it - laughter.
