11-06-2016, 10:11 AM   #1
K3, power button stuck
Hi all,
My K3 is now 2 years and the power dial started to move really difficult. It is hard to turn, and it can only be turned on/off by even pressure on both sides of the dial. Pushing the little knob does not make it move.
Any thoughts, or something for warranty?
11-06-2016, 11:04 AM   #2
bobbotron's Avatar
QuoteOriginally posted by dicks Quote
Hi all,
Ah, that sucks! The power switch is pretty tight to the body - my initial thought is some lint or dirt is stuck in there. I've had luck using a toothpick or thin plastic to de-lint such things as iPhone/headphone jacks, but you wouldn't be able to get one under there.... Small chance it would pop off, but seems more likely it wouldn't... I think warranty might be the way to go.
Perhaps you could fit fine dental floss under there?
11-10-2016, 02:03 AM   #3
I got the same problem, I use a piece of paper, or you could try dental floss to clean out the dirt, and wash it with tap water this will help, the camera is water-resist right !
06-24-2017, 08:54 PM   #4
I drop alcohol onto the side of the dial and turn it repeatedly to clean up the inside, and then again under running water and that worked, but some other buttons became bad contact over hard use I couldn't fix that.
dslr, k-3, k3, move, pentax k-3, power
Pentex MV film release button stuck AFDAFSSA Film SLRs and Compact Film Cameras 2 10-17-2016 08:46 AM
Pentax FA 80-200/f 2.8 power zoom button sorins Repairs and Warranty Service 4 03-12-2016 12:41 PM
K3 slow power ON ? jpzk Pentax K-3 & K-3 II 12 03-04-2016 07:42 PM
K3 stuck in MF Sigmund Troubleshooting and Beginner Help 38 06-01-2015 07:57 AM
AF/MF button stuck mde1970 Troubleshooting and Beginner Help 4 08-27-2012 02:32 AM
All times are GMT -7. The time now is 06:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
