Originally posted by stevebrot Steve
* The communication is through a modulated light pulse from the controller (on the camera) to the slaves. The control pulse has a signature specific to the set channel. The slaves must be able to "see" the controller light pulse (either direct or reflected) in order for the wireless sync and control to work.
I thought I was done with posting on this thread but your in depth on-topic responses drew me back in. Thank you for the clarifications and confirmations I appreciate those responses.
As to the off-topic comments on the modulated IR control of off camera speedlights, we are both right. I've been aware of the use of IR all the way back to the introduction of the thyristor flash control back in the early 70's (yes I predate that), but was curious to see if anyone else was aware that there are options available. Probably should have approached it differently. I rarely use P-TTL, or for that matter off camera speedlights, preferring radio trigger manual monolights. I only have one out of several speedlights that I think is even compatible with Pentax, P-TTL, maybe I need to experiment with it.
In any case, I would suggest all to read up on "Non-Flash-Emitting Triggering Devices". If you don’t use a flash to trigger the remote strobes, you can use a TTL-flash-compatible wireless trigger, or “transmitter,” seated in the camera’s hot shoe.
This can be an optical/infrared or Radio Frequency (RF, or simply radio) system.
Radio systems are the best choice under conditions that are less than optimal for optical systems. If you've ever had optically controlled speedlights fire in your face unexpectedly or not fire because of line of sight obstacles, you'll know what I'm talking about. Radio signals can reach distances of several hundred feet, which gives them an advantage when the remote speedlights are positioned outside the range for a typical optical device. Radio signals easily circumvent most obstacles, so speedlights attached to radio receivers can be hidden away and still fire as needed. This becomes more important as you start adding groups of multiple flashes. There are also "hybrid" triggers which use both radio and IR signals. Some of the newer speedlights include a 2.4GHz transmitter that have the option of two way digital communication with remote flashes or optical control (for backward compatibility). As I said rarely use P-TTL so I haven't had the need to determine the compatibility of these devices with Pentax, in a true P-TTL application, but the literature on several claim to be compatible in a wholly digital manner. I know there are several others out there, including I believe, the low end Yongnu (though I haven't verified that) but here's a couple of examples to start.
Catcus V6 - The 2.4 Ghz V6 transceiver comes with a multi-system shoe that supports TTL pass through. With TTL pass-through, the TTL flashes behave as they would when directly connected to the camera hot shoe with Canon, Nikon, Olympus, Panasonic, Pentax, and Fujifilm via one single unit;
Cactus Wireless Flash Transceiver V6 | CACTUS
Metz M400- 2.4 Ghz flash.
TTL flash mode (digital only), Pentax, P-TTL flash mode and P-TTL remote operation.
Ausstattung: Metz
Perhaps someone who's actually had operation experience with digital P-TTL communication (rather than the speculative comments herein by all) can speak up on the subject.
