Show Printable Version 17 Likes Search this Thread
12-14-2016, 09:00 AM   #31
MJSfoto1956's Avatar
easy: DA* 60-250mm
M
12-14-2016, 12:36 PM   #32
K5 owner here... only one lens? (and I infer that size/weight is therefore important) 18-135.
Great all around lens.
Yes I have "better" lenses in my stable, but if I could only bring one, it has the best compromise of size/weight/range/optics.
Yes, I would sneak my 15ltd into a pocket somewhere if given half a chance.
12-14-2016, 01:00 PM   #33
RobA_Oz's Avatar
Welcome to Pentax Forums, Paddy.
I've done more than my share of overseas travel with a DSLR, and while it's good to have primes like the FA31 that you can exercise your mind with occasionally, most of the time I've found the DA18-135 has been my mainstay on APS-C bodies, including a K-3. I'm also one of the group who likes to put a DA15 in my bag, for those times when 18mm is simply too long (and there are lots of those moments in Europe).
12-14-2016, 01:05 PM   #34
normhead's Avatar
QuoteOriginally posted by MJSfoto1956 Quote
easy: DA* 60-250mm
M
Even moreso if you have a K-1.
12-14-2016, 02:14 PM   #35
E-man's Avatar
I don't own a K3 but of the lenses I own, my choice would be my Tamron 28-105. It's easily the brightest, most versatile lens I've got.
12-14-2016, 02:27 PM   #36
pres589's Avatar
I can't imagine suggesting the combination of aps-c with a lens that goes 60mm at the wide lens unless the goal was very specific and not general street carry. Mix a 60-250 with a second lens like a 17-50, 20-40, et cetera? That I would buy in on but that wasn't at all the question asked.
12-14-2016, 03:08 PM - 1 Like   #37
Jonathan Mac's Avatar
A one-lens option really needs a fast aperture for depth of field control and low light, so I would rule out anything that doesn't go to at least f/2.8. Flexibility in a lens is more than focal length range.
12-14-2016, 03:10 PM   #38
I would say DA*55/1.4 in a heartbeat. This lens amazes me on K-5iis each time. I am sure on a K-3 it will be jaw dropping.
If one zoom then DA*50-135/2.8 that would be.
12-14-2016, 03:43 PM   #39
I like 20 mm on 1.5 ASP-C body. Therefore, I would vote for a DA21. Reasonable price, light weigh, well build, sharp, and very beautiful starbursts effect limited prime. If Pentax makes it bit faster + WR feature, it would be a very welcome upgrade. However look at its current price and what it can do, I have no complain at all.
12-14-2016, 05:51 PM   #40
Wow! So many answers! Thanks guys, definitely alot to check out and photos samples to view. The trip is to Beijing, so it will be mostly monuments and hopefully some street style photos. Coming from fixed lens compacts, I suppose I am not the SLR mindset yet as regards to swapping out lens. The Ricoh GR 28mm is great and I like that field of view, but some times I'd like to get in closer, but i am not really into long lens stuff like wildlife etc. My thinking was a lens that would cover at least 28 -85, so that i would only have to carry one camera.
I would go for more lens later, but financial considerations would limit me at the minute to one good one, although i would be prepared to pay for a really decent lens. My trip is not until April, so I have time to get used to shooting the K3.
a quick question on the FA/DA lens, what are the differences.. is one for crop sensor and one for full frame? so if I see a 55m DA 1.4, that's 55mm for a crop sensor?
12-14-2016, 06:17 PM - 1 Like   #41
WPRESTO's Avatar
For Beijing = buildings, people, indoors, outdoors. I would certainly opt for the 16~85mm. You'd probably have to kick up the ISO for interiors, but IMHO the versatility far outweighs gaining two f-stops. The FF equivalent would be 24~127mm, an excellent range for the type of photo-ops you're likely to encounter on such a trip. If you really think you need the extra apertures, a Sigma 17~50mm (constant f2.8) or Sigma 17~70mm (f2.8 to F4) might also serve, but, I predict you will want something as wide as possible. Also, fair warning, sometimes there are limitations or prohibitions on photographing interiors.
12-14-2016, 06:58 PM   #42
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by PaddyKajinski Quote
do yourself a favor and start checking out the other parts of the forum for the helpful info and hints. heaven knows I need to
Comprehensive Pentax Lens Guide - Gear Guides | PentaxForums.com
"You may know that all Pentax K-mount lenses ever made can be attached to all Pentax DSLRs, including the mirrorless K-01 and the latest full-frame K-1. But evolutionary differences between each lens series mean that supported features may vary. This guide will make you an expert on Pentax lenses by first explaining lens terminology, then highlighting the main differences between past and present lens generations.
Read more at: https://www.pentaxforums.com/articles/gear-guides/comprehensive-pentax-lens-guide.html#ixzz4SrsSFdvD"
that might be a good place to start
12-14-2016, 07:04 PM - 1 Like   #43
Arjay Bee's Avatar
QuoteOriginally posted by Qwntm Quote
One lens for a K3 would be the HD 21mm LTD.
+1 for a small and light kit
12-14-2016, 07:18 PM - 1 Like   #44
WPRESTO's Avatar
FYI: An image taken with the 16~85mm, 2.5 seconds @ f9, ISO 800, uncropped and a selective crop.
12-14-2016, 08:24 PM   #45
AquaDome's Avatar
If I were allowed only one lens with the K-3...
For work I use the Sigma 17-50 almost exclusively.
My favorite is the DA*50-135. I guess I would have to own two K-3's.
dslr, k-3, k3, lens, pentax, pentax k-3, sigma, trip
What if you could only have 1 camera with one lens.... RonHendriks1966 Pentax DSLR Discussion 104 11-05-2016 11:31 PM
If you were to take one lens to shoot landscapes... awscreo Pentax SLR Lens Discussion 55 09-11-2016 05:42 AM
If you had to choose one filter for one lens... Jeff Pentax Camera and Field Accessories 16 06-24-2016 10:39 AM
What fast lens would you choose for portraits (if you were me)? Metalwizards Pentax SLR Lens Discussion 23 01-25-2011 05:36 AM
Which macro lens would you pick if you only had one choice? ViS Pentax SLR Lens Discussion 27 11-09-2008 08:46 PM
All times are GMT -7. The time now is 11:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
