Originally posted by kchamber4 Check the setting on the button on top of the menu controls. The one that allows you to select single, multiple, remote, etc. Sorry, my camera is at home and I don't recall the name. Near the right is a setting for multiple exposures. If that is turned on it will do this. The reason for the odd number of exposures is due to the time between shots. If you turn off the camera or let it idle for a long time, it will save the current set of exposures and start a new one. I had this happen at my mother-in-laws funeral and didn't realize it. I thought something was wrong with the camera and I missed a lot of family pictures because I couldn't figure it out.
This might not be the cause but it is the first logical place to check.
Yes, that's what I meant by having to click on the exposure button and then either move 6 right or 3 left to get to multiple exposure, but I don't see how I could have accidentally done that.
You did clarify why it seemed that some of the multiple exposures were only 2 images and seem 3 or 4 or 5. Thanks for noting that delaying long enough between shots causes it to be saved.
So... it's possible (probable) that somehow it got to multiple exposure, and those single shot images in the mix were due to a long enough delay. That explains that anomaly. Thanks!
Quote: @JohnX: As it's a used unit, check none of the buttons have been reprogrammed to allow one-touch access to multi-exposure. In any event might be worth doing a factory reset to ensure no other surprises are lurking.
Yeah, I did that, and I've checked the buttons, and they all function as expected. I keep the mode dial locked, so I didn't accidentally slip into a user mode.
