Originally posted by pschlute You are assuming here that the camera will only adjust aperture to give your three bracketed exposures. That is not the case
But why wouldn't I assume that, if I'm in M mode with the green button functionality set to Av Shift? Surely that suggests that bracketing should adjust the aperture and nothing else. In that instance, it should - I would think - impose a maximum aperture setting that ensures all of the bracketed shots are within the range of available apertures.
In any case, if it's adjusting more than the aperture as you suggest, why hasn't it adjusted the shutter speed or ISO in the final "+" shot of the example I gave? The "0" and "+" shots had exactly the same aperture, shutter speed and ISO setting.
As far as I'm now aware, setting green button functionality for M mode defines whether aperture and shutter speed can be adjusted by the camera (P), aperture only (Av) and shutter only (Tv), and these also affect how the bracketing exposure is controlled in the same way. Otherwise, what's the point of setting green button functionality to affect bracketing (and it clearly does affect it)?
