04-06-2017, 09:06 PM   #1
Body Cap Cover For Pentax SLR Cameras
Is there a good quality, screw on, won't fall off, Body Cap Cover For Pentax SLR Cameras. I'd like to have my K-3ii in a case without the lens attached.
Thanks, BLB511
04-06-2017, 09:27 PM   #2
Tako Kichi's Avatar
Body caps for the K-3ii are bayonet type not screw on and they can be found on Ebay for little cost. I have bought them in pairs in the past along with the rear lens cap.
04-06-2017, 09:42 PM   #3
Tas
QuoteOriginally posted by blb511 Quote
Thanks, BLB511
Have a look for the body cap that comes with the K-1. It locks onto the body and needs the lens release button to remove it. I can't see it at B&H, though they do list a 'Pentax KII' body cap as not yet available.
body caps pentax | B&H Photo Video
An alternative is to look for the front cover of a K mount teleconverter as these will have a locking or screw on cover that can act as a body cap.
Tas
04-06-2017, 09:49 PM   #4
Your only alternative if you really prefer to use a screw mount body cap would be to pair a K mount to m42 adapter with an m42 body cap.Both B&H and Adorama (and probably Amazon) still sell the m42 body caps cheaply (sub $5) ,Adapters can run from $10 (Fotodiox) all the way up to $90 (genuine pentax). So you could get it done for under $20. The Fotodiox would be more than sufficient to just hold a body cap in storage.
04-06-2017, 09:56 PM   #5
KEH usually carries lots of the bayonet caps.
However, I'd recommend the push-on caps as they don't put any wear on your mount contacts.
04-07-2017, 04:19 AM   #6
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
Here is my recent purchase-
Movo Photo Lens Mount Cap and Body Cap for Pentax DSLR Camera
I also purchased this-
Matin Digital SLR Compact Camera Body Case
On a recent trip I couldn't take a dedicated camera bag and my K-3 and lens couldn't fit in my pack when joined, let alone with some kind of additional protection. The above protected the K-3, and my lens (only had room for one and chose the 18-135) was similarly clad in a neoprene cover.
04-07-2017, 06:04 AM - 2 Likes   #7
I use the DA 40mm XS
04-07-2017, 06:07 AM   #8
There are five body caps available the first in the screw m42 mount cap, the second is the push fit black or clear cap, this usualy supplied with the body when new, the third is the early bayonet type with asahi pentax written on it, this latter had the asahi name was dropped these also had a circle at the 12 o/c position (mounting point indicator to line up with the red dot on the mount) and white or red paint inside the circle, to match m or a type lens cameras, a second version of this cap has no paint in the circle and the addition of a circular tube moulded on the inside in the mounting flange circle, the locking button of the mount locks into this and secures the cap on, and last of all the new K1 cap that locks on as well.
04-07-2017, 06:29 AM   #9
04-07-2017, 07:56 PM   #10
Man!!! The responses we're GREAT. Thank you everyone for all the good info. As a newbie... I can tell you your replies are truly appreciated!
04-09-2017, 03:10 PM   #11
QuoteOriginally posted by robthebloke Quote
So do I!
body, body cap, cameras, cap, dslr, k-3, k3, pentax, pentax k-3, pentax slr, slr
Cameras cameras cameras Lurch Pentax DSLR Discussion 16 04-14-2013 02:54 AM
Super Program Winder Drive Cap/Cover Mister Pita Pentax Film SLR Discussion 5 04-15-2010 05:48 PM
All times are GMT -7. The time now is 03:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
