Originally posted by jatrax If I understand right you want to use the remote shutter release ability of the Cactus v5 transceivers to remotely fire the shutter? I think the camera is 2.5mm and the Cactus port is 3.5mm so you need 2.5 on one end and 3.5 on the other of the cable. Did your Cactus v5 come with any cables?
---------- Post added 06-03-17 at 04:06 PM ----------
Here is the Cactus cable:
https://www.amazon.com/Cactus-Shutter-Sub-Mini-Samsung-Cameras/dp/B008559VE8...ntaxforums-20&
---------- Post added 06-03-17 at 04:07 PM ----------
And link to the Cactus website cable page:
Cables | CACTUS
You understand exactly. The remote shutter firing you described is what I was interested in. Thanks for the 2.5 and 3.5 specs also. I ordered my V5s (two 2 packs), 4 in all, but will not receve them for a few days. Do you know if they come with a cable like we are discussing already in the box, or would I have to purchase the one you listed? Thanks for your informative/attentive response, that helps.
---------- Post added 06-03-17 at 08:08 PM ----------
Originally posted by stevebrot Yes, the camera is 2.5mm. The connector is 2.5mm TRS with three contacts per the photo below:
I don't remember the specifics of the contact mapping, though the scheme is shared with several Canon bodies (Rebel/Rebel XT/Xti/Xsi/DS/EOS 30D/33D/50D/60D/300 and probably several others).
Thanks for the confirmation of the plug size Steve. I appreciate your help.
---------- Post added 06-03-17 at 08:51 PM ----------
I looked and found that the V5 duo (2 packs) supposedly come with the following:
"Cactus V5 Transceiver (2) - Flash Stand (FS-5) (2) - 3.5mm Plug Cable (CA-350) - 6.35mm Plug Adapter (PA-635) - PC Sync Cable (CA-100) - AAA Battery (2) - Cactus 1 Year Warranty"
In that listing of contents it describes (2) 3.5 mm plugs (CA-350) for the off camera strobes and V5 units connected to them. It also describes (2) PC Sync Cables (CA-100), which have the one end that is for a PC port.
So it seems that the Cactus cable "CACTUS SHUTTER CABLE FOR CANON PENTAX SAMSUNG (SC-C1)" that Jatrax pointed out is an alternative for the remote firing I described. I will wait and see what I get with my V5s, and if I find I need the cable Jatrax described I will get it.
Thank you to you both for the helpful responses.
