Originally posted by Mayberrygal Thank you for this information and the suggestion about the Wein Safe Sync. I forgot that they make one specifically for PC ports. As for using my multimeter to determine voltage, I understand I would put one probe in the PC port, but where would I put the other probe?
Take a look at this closeup of the PC socket. There are two metal surfaces on the corresponding cable end. Your test probes contact these surfaces. Must be careful to not let either probe short the outer and inner contacts directly. As suggested above, try contacting the monolight mfgr.
Prontor-Compur - Wikipedia
Here is a list of strobe system voltages that may be useful:
http://www.botzilla.com/photo/strobeVolts.html
And a discussion of the issue with examples of why you should procede with caution:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwj...yPvdFQ&cad=rja
