Thank You all!
Problem appeared when using Sigma 30.1,4 HSM, some side AF points have very consistent focus problems, while other didn't.
Recently I retested my body with Sigma 17-50 HSM (with DIY Lens align grade) and focus error was marginal/didn't exist (need to confirm, but it is possible that those errors were due to my problems with exact camera positioning and alignment).
Still, problems with 30 1,4 seem to be very consistent, some af points seem to focus very well, while others don't (does't matter if they are extra sensitive or not). I will do some more tests and post the results and examples here in few days.
Clackers, below are the links where I got that info from (or so I thought). Now I see it was probably a misunderstanding/overinterpretation on my side.
RiceHigh's Pentax Blog: K-3 Debug Mode and Menu Quote: 1. The debug menu enables af-adjustment for each auto focus point, These adjustments are added to the AF-Finetuning value.
and here:
RiceHigh's Pentax Blog: K-x Debug Mode Tutorial - AF Adjustment Quote: Btw, don't change the "AF Test" and "AF Area Number", keep them both at the default Zero 0. What I am interested is to adjust the central AF point only and to eliminate the Back Focusing tendency that I have encountered.
Problem appeared when using Sigma 30.1,4 HSM, some side AF points have very consistent focus issues, while other didn't. Recently I retested that with Sigma 17-50 HSM and focus error was marginal/didn't exist (need to confirm).
