Originally posted by OJGoreng Hey,
Today while I was photographing a displaying Goshawk with my K-3II, an interesting thing happened. At some point right in the middle of a continuous series of shots, the camera started to vibrate and rumble audibly, pretty much like an exaggerated version of what happens when you engage the dust removal routine; it was rather reminiscent of the mirror flop issue that I have experienced a few times with my K-3, although now no mirror flopping was involved and the camera just kept shooting properly exposed images. However, the images taken during that rumble were blurred compared to the ones taken before it happened, all the more obvious because it happened in the middle of a series. Problem persisted until I switched the camera off, but thankfully did not return after I switched it back on straight away (i.e. I didn't need to pull the battery to remedy the problem).
It seems to me the shake reduction mechanism went crazy for a bit. This is new to me, although I don't read every thread on the forum. Has this happened to others before?
Details that may or may not be relevant: I was shooting at AF-C, high frame rate setting, with DFA 150 -450mm. Temperature was about 20 C, air humidity close to saturated (just before it started to rain). I've taken about 41,000 shots with this camera (bought new), first (and so far only) time this has happened.
It's happened once to me with a K-3. Like you described, I was just walking around snapping photos here and there and suddenly the whole camera was vibrating and making an audible (loud) buzzing noise. All controls were unresponsive, but I could turn the camera off and on again, and the problem stopped. Only lasted 1-2 seconds. I have the latest firmware, and it's only happened once in 100K shots.
I've had mirror-flop, mirror-flop with the camera self-rebooting, and complete freezes (this is extra annoying when the power switch no longer works and you need to take the battery out - if you've got a grip on, then you need to disconnect the grip to be able to pull the battery from the body.)
