Originally posted by frogfoot Well, may be it really is. I shoot many times under a rain with my former cameras: K-7, K-5 and K-5II with 18-55 WR, 18-135 and 60-250.. and everything was ok.. But the first rain with K-3II... and it's broken...
I sympathise, and I understand that you're disappointed and frustrated. But, I don't think your isolated experience - nor the tiny number of other reports we've heard of - is a solid basis for concluding (or even suspecting) that the K-3II is generally less weather-resistant than previous models. You might
wish to believe it, given your disappointment, and you'd be forgiven for doing so - but it doesn't really stack up without a lot more evidence from many users.
Similar to you, I've owned a K-7, K-5, K-3 and K-3II amongst numerous other cameras. I still own the latter three, all of which have been used in wet weather and/or sea spray etc. (with a little bit of care, admittedly). All three have been fine so far and are used regularly.
Maybe you got a bad example... It happens. And it's highly probable that all K-3II's are not made absolutely equal... as with any product, there are manufacturing tolerances to consider. My K-3II may be slightly more weather resistant than yours, and someone else's K-3II may be more weather-resistant than mine, depending on the machining and finish of the case components, manufacture and placing of rubber gaskets etc. All I can say is, I've not yet had a problem with water ingress on any of my weather-resistant Pentax cameras, including the K-3 and K-3II (which are my main day-to-day bodies). They've all been equally good in this respect.
The overwhelming evidence here on PentaxForums (which is, bar none, the largest Pentax user group by far) suggests there are
very few people,
regardless of which Pentax weather-resistant model they shoot, that have had water ingress problems. It can happen, of course, but the number of reports we've seen really doesn't suggest the newer models are any worse than the older ones. Nor do those few reports - yours included - suggest there's a general problem.
But, again, I do sympathise
