Originally posted by awscreo My dfa 28-105 has shutter shock from 1/30 to 1/200, pretty broad range. I meant to call them, see if it's maybe fixable somehow under warranty, so far I haven't seen anyone on pf with such issues with this combo.
Originally posted by Adam The shutter can cause visible vibrations between about 1/90s and 1/180s, and this looks like it might be an example of that. There was a long thread on this topic earlier this year.
Originally posted by awscreo I've ran into mirror shock myself with my 28-105, since then I only use LV mode with ES option on to eliminate any possibility of this effect. Kind of a pain when I'm hand holding some of my lenses, but I guess nothing is perfect.
Originally posted by richandfleur If this is the case, you'd hope Pentax would have addressed this in the firmware, and disabled the SR system at those shutter speeds?
Originally posted by Adam They did, they added the electronic shutter option. SR is not to blame, it's the shutter. But yes, SR gets disabled when ES is on in the K-1.
There was another lengthy thread on the topic, which ultimately resulted in identification of the problem (note that this was before they added the ES solution):
Help needed figuring out D FA 28-105 - PentaxForums.com I am a bit confused. All of these comments are about the
K-1. This thread is about apparent artifact on the
K-3. Was there a branch in the road that I missed?
Just my two cents, I believe that SR is a red herring here. The blur on the bird looks to be subject motion. In regards to the general softness...At first I thought something optical, but at present, I don't think it is possible to rule out camera motion or missed focus. I also wonder about moisture condensation on the front element and/or atmospheric refraction.
If there are problems with SR with the lenses in question at those shutter speeds, it should be easy enough for the OP to test for under conditions more controlled than over water and snow at 0-2 C. I have done plenty of hand-held work with my K-3 in the range of 28-105mm at moderate shutter speeds using SR and have not seen anything unusual. I don't have any glass over 200mm and can't test on the long side.
