Originally posted by UncleVanya My understanding us that the exif is just numeric data read by the camera and saved to the file unaltered. Interpretation of that data comes from the exif viewer or program used to read it later. I would look at your new converter as the culprit. 3rd party lenses often duplicate existing codes which makes identification difficult. This happens to Nikon and canon uses as well.
If your old raw converter works to me that suggests the problem isn't in the file data but how it is read.
I discovered my problem with viewing the EXIF file, it was an older version of ExifTool that was accessed by ExifToolGUI so that problem is solved but I've got to find a solution to hack good old DXO PhotoLab into using a slightly different module for my go to lens. What I've found is that the DXO Pentax K-3 Sigma 18-200mm F3.5-6.3 II DC OS HSM Module can be "tricked" into loading. It seems that DXO labs hasn't gotten off their butt to up grade their module to reflect the newer Sigma 18-200mm F3.5-6.3 DC MACRO HSM lens even though its been marketed for 3 yrs now. I'm not a good command line programmer at all so Phil Harvey of ExifTool is working with me to get the correct LensID into the EXIF file in the correct area.
The old raw converter used the adobe Camera Raw files and the converter allowed you to select the needed lens profile from a list.
Larry
