Camera display not registering and some photos are blacked out
I have a K-3 with a Pentax 18-135 mm lens for my work. I've had it since last April and am using it to take photos of artifacts inside a hood. The following problem has only happened to me once or twice in the last few months. I haven't changed any settings since I started, and I have taken thousands of photos with this camera.
Today when I tried to take a photo with the digital display on, rather than showing what the lens was pointed at, it was blacked out with flashing red readouts along the bottom--exactly what you see when you forget to take the lens cap off. (The cap was not on). Sometimes I could turn the display off and back on, and it would go back to normal, other times it would not. This would also happen sometimes when I switched between the playback mode and camera, also when I turned the camera off and back on. I haven't been able to discern a pattern of when it works properly and does not.
After a little while I stopped using the digital display altogether and continued photographing, which helped for a little bit, but then it starting saving blank, blacked out photos. Now the frequency of both of these problems has increased, and I'm unable to take photos consistently.
I've turn the camera off/on, taken out the battery (it's been fully charged while this has happened), updated the firmware, checked for dust, cleaned the lens and camera, and reset to factory settings. None of these actions have changed anything.
Has anyone else experienced anything like this? I thought I'd check around to see if there's a simple fix before anything else. Thanks.
