01-26-2018, 04:13 PM   #1
bxf's Avatar
Flash stuck
I attached my AF540 to My K-3, took some snaps, and now I am unable to remove the flash from the body.
Is there anything I should be doing other than simply persisting? Is there some pin that could be holding the two units together?
Edit: just found this one: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/6874-flash-tota...k-hotshoe.html, so subject has been covered previously.
01-26-2018, 04:18 PM   #2
jatrax's Avatar
Make double, double sure that the pin is completely retracted. Use the wheel to retract it and make sure it is all the way up. I had a similar issue and after a lot of work discovered that though the wheel seemed to be all the way retracted it was not.
01-26-2018, 04:19 PM   #3
pjv
Otis Memorial Pentaxian
pjv's Avatar
Hi Bill, if the lever pin is not retracting completely, you may have a problem. Good luck.
01-26-2018, 04:19 PM   #4
jatrax's Avatar
QuoteOriginally posted by bxf Quote
To be clear. Yes there is a pin that locks them together. It is retracted by turning the locking wheel on the flash. It must be completely retracted or the flash will not come off.
01-26-2018, 04:29 PM   #5
Ex Finn.'s Avatar
The plastic piece that retracts the locking pin is broken, unscrew the 4 #0 JIS crews from the flash base and go from there.
01-26-2018, 05:41 PM   #6
Ex Finn.'s Avatar
Found some old pictures.
PENTAX K-5  Photo
01-26-2018, 05:45 PM   #7
Ex Finn.'s Avatar
After getting the flash head off.
PENTAX K-5  Photo
01-26-2018, 05:50 PM   #8
Ex Finn.'s Avatar
More.
PENTAX K-5  Photo
01-26-2018, 05:57 PM - 2 Likes   #9
Ex Finn.'s Avatar
The broken part responsible for all the anxiety!
PENTAX K-5  Photo
01-27-2018, 03:22 AM   #10
Perkele an excellent, informative and I am sure helpful post. Just what forums should be all about
01-27-2018, 03:26 AM   #11
bxf
bxf's Avatar
Got it off, thanks guys. Ex Finn's photos made things very easy. Having a long thin screwdriver makes it less likely to scratch the camera body.
I wanted to see the smaller component of "The broken 3 cent part" in the last photo, but it is nowhere to be found, For that matter, where do I get a new one for 3 cents?
Cheers,
Bill
01-27-2018, 03:18 PM - 1 Like   #12
Ex Finn.'s Avatar
I discarded the locking pin, just have been using the lever by itself with no problems.
01-28-2018, 08:16 AM   #13
Mikesul's Avatar
Is this pin issue just for the AF540 or do later Pentax flash models have it? I have never run into it. Maybe later models dropped it.
03-01-2018, 10:53 PM   #14
The lock pin is on my AF-360FGZ also...Ex-Finns post is great info if you have issues with the flash releasing from the hot shoe.
dslr, flash, k-3, k3, pentax k-3
Altura flash transmitter stuck on the hotshoe Yyh Troubleshooting and Beginner Help 8 03-16-2017 10:32 PM
pentax kx flash stuck pixxie Troubleshooting and Beginner Help 19 12-15-2014 02:08 PM
K-50 Control Lever diaphragm stuck. The Flash fires when it is closed. Meridio Troubleshooting and Beginner Help 5 12-13-2014 12:21 PM
KX stuck in autofocus, but switch is stuck in MF icywarm Troubleshooting and Beginner Help 4 08-07-2012 07:21 AM
PK-M 50/1.4 ring stuck, back-plate screws stuck fungiman_md Troubleshooting and Beginner Help 4 05-10-2011 12:54 AM
All times are GMT -7. The time now is 11:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
