Originally posted by Larrymc AF Fine Adjustment Question!
The K3 manual (the system is identical or similar to other Pentax SLRs), textually says.
1. Apply all "Applies the same adjustment value to all lenses"
2. Apply one "Save an adjustment value for the lens being used. (Up to 20 values)"
We must also consider that:
"Apply to One" allows you to store an AF calibration for a single/specific AF optical (F, FA, D FA, DA).
"Apply to All" allows you to store an AF calibration for a general NON AF optical (screw, K, M, A).
If,
After saving with OK "Apply to all" an AF calibration for a generic NON AF lens (screw, K, M, A), an AF lens (F, FA, D FA, DA) is mounted on the camera,
then the calibration chosen for "Apply to all" will be adopted.
Yvon Bourque in your book says:
Choosing Apply One would correct the current lens attached and would keep the results in memory. Choosing Apply All would apply the corrections to all lenses mounted on the camera.
