Originally posted by Infinite Ascension I did it and set it for 5 images, and it just took 5 images, it didnt merge them at all. What am I doing wrong? Was using a manual lens, could that be it?
There are a couple of different settings. Bracketing will take 3 to 5 exposures at different exposure gaps and save them to your card. It is your job to combine them after the fact. If you want to take an HDR photo then use HDR setting, but this is primarily a jpeg setting.
Multiple exposure I think requires you to hit the shutter each time for a specified number of shots. Interval mode will let you set a specific time and the camera will take a shot up to a specified number of shots. Each successive shot will be averaged with the shots that came before which allows for the simulation of long exposures. So the first frame will have minimal blurring of water and sky and after 30 or 40 shots there will be quite a bit.
I posted this elsewhere, but this is 50 shots averaged with the K-1 II (I don't own a K3 II) and you can see what it did to the sky. It also has some blurring in the foliage as well, but the actual shutter time was something like 1/60 second.
