Originally posted by Adam
Is the flash set to deliver 1/1 exposure, and are both the flash and camera set without a flash exposure compensation?
This setting is not available, because I have only A or M modes, no P-TTL. But see below...
Originally posted by CarlJF
As I remember it, with the 360 you had to change a slave setting from the default SL1 value to 2 (or the other way around). By default, these flash were set to work as dump optical unit and not P-TTL, which was new at the time these flashes were launched and thus not supported by most camera. This is why you can only choose A or M mode. And the pictures are underexposed because the 540 is trigerred by the camera preflash, thus not synchronized with the shutter.
In fact, the manual leads me to use SL2, due what I take to be an inconsistent use of the term SLAVE. See below...
Originally posted by pschlute
The default setting should be SLave mode 1 which is the P-TTL -wireless compatible mode. The SLave 2 mode is for the dumb flash mode you describe.
To the OP. Is this a version I or II AF 540 ? Make sure your slave mode is in SL 1. Make sure your shutter speed on the camera is below your sync speed ....1/180 or less. What lens are you using ?
And now we have the correct solution, which I discovered myself as I was experimenting with various settings
When setting the M/C/S (Master/Controller/Slave) mode, one is instructed to use Slave for wireless use. However, in the Slave Mode Setting instructions it says:
SL 1: When photographing in wireless mode
SL 2: When photographing with slave flash
It appears that the use of the word Slave here is different from its use in the M/C/S setting. Here, as pschlute points out, SLAVE (i.e. SL2) refers to a dumb flash. When set to SL 1, P-TTL mode is available, and the flash works correctly.
By the way, is Auto Zoom supposed to work in wireless mode?
Thanks for all replies.
