Originally posted by othar -Are you by any chance in Bulb mode? Although then the mirror would come down when pressing the shutter a second time. (M mode with a 30 sec exposure will result in an inability to do anything for that timelength)
That would be "B" mode using option 2. Option 1 allows the shutter to close on button release. Long exposure time in any mode will also result in similar behavior, a good example might be having the lens cap on at the start of the exposure in green, P, or Av mode.
Originally posted by othar -another possibility is the "mirror flap" problem some K-3s develop
Mirror flap (more descriptively "runaway mirror") is rapid machine gun cycling of the mirror on shutter release found in some early production K-3. The problem was isolated and fixed in production summer of 2014 and a warranty fix offered to existing owners at that time. A firmware patch to detect and abort the runaway condition was offered in firmware v1.11 fall of that year.*
That aside, camera lock-up such as this is often an indication of a power issue (low or old battery) or a problem with the camera's electronics due to defect or something like moisture intrusion or physical damage.
* My K-3 was made November of 2013 and is in the range of effected serial numbers, but has been free of the issue.
