Originally posted by JimJohnson where is makes the most difference is what systems will be in play after the image is transferred out of the camera. You would think the Adobe color space would be easier if you used Adobe's software for post processing. Lightroom/Photoshop doesn't really care, and doubly so if you are post processing from RAW. I used to use the Adobe color space - and still have thousands of images in that color space. In almost every case I have had to convert to the sRGB space before proceeding. All but a handful of more expensive monitors work in the sRGB space, most consumer to semi-pro printers prefer if not require sRGB, for sure you need to use sRGB for any web site you send images for display.
Deciding on PEF vs DNG for RAW images is a different can of worms.
Many thanks for all of you.
I take my photos in RAW (DNG) then AURORA HDR and some times LUMINAR.
---------- Post added 26-04-21 at 23:02 ----------
Originally posted by Paul the Sunman There is some confusion here. "Colour profile" is used by different people to mean two very different things: "custom image" (in Pentax language, Picture style in Canon, Picture control in Nikon, Creative style in Sony, etc) or "colour space".
On the K1, "Custom Image" may be chosen from Auto Select, Bright, Natural, Portrait, Landscape, Vibrant, Radiant, Muted, Flat, Beach Bypass, Reversal Film, Monochrome and Cross Processing. This comes under "Controlling the Image Finishing Tone" in the manual. These are applied to jpegs (and can't completely be undone), and to the preview jpeg embedded in Raw files (and are therefore just the starting point of your post-process edit). In Raw, you have the full colour data irrespective of choice of custom image. You may set custom image using the 3 o'clock button on the 4-way controller (on the K1). Is this what the OP was referring to?
On the other hand, colour space is either sRGB (mostly used for web applications) or AdobeRGB (a larger colour gamut). These specify which colours are to be stored, and only affect jpeg. They are set in the Camera 2 menu. If you shoot Raw, you get the full colour gamut that the sensor can recognise. This is distinct from the custom image setting, which specifies emphasis or de-emphasis of parts of the available gamut (more vibrant reds for example).
Anyway, in each case, Raw is what the name says, "raw". You get a dump of the lot.
Many thanks.
Your information is as it seemed to me that it worked.
