Here's the thing: I cleaned the connectors on the grip and camera: Nothing. Still flickering. I tried changing the battery souce: Nothing. So far no change. I also tried to do a pixel mapping on the sensor. Then I got a error message that there was not enough power to do so. Even though batteries are fully charged (or so they say). I removed the grip: And pixel mapping did then work. So then I changed a battery from my old K7. Then the flickering stopped. Or didn't flicker that much. So there's obviously something strange with the Grip I think.
But the Liveview works stable all the time. doesn't matter what battery.
---------- Post added 07-08-21 at 12:16 PM ----------
Originally posted by Fogel70 Check if there is any difference with the grip turned on or off.
If the grip is on and you use the camera in landscape orientation it is easy to touch the buttons on the grip, making the camera behave unexpected.
Uhm... so I tried this as well... and with the new battery there was no flickering at all. If this is the real reason to this then I have no words...
But thanks!
It's strange to think that pressing buttons on the grip while in landscape does this.
