paref
Originally posted by stevebrot The K-3iii uses the same type of wired remote fitting and protocol (shared with many Canon models) as previous model Pentax dSLRs. As far as the camera is concerned, the signal from the trigger (relayed through a dongle) is the same as a shutter press.
correct. the only difference is the response time of the trigger, compared to human reaction time. The best approach is to stop down all the way with ISO set as low as possible, and just lock the shutter open. if you are going to get a flash you have just as much chance with this approach.
the other thing to remember when using the trigger is to make sure the trigger goes directly to the shutter release and not the AF contact. or turn AF off so that your preset focus is not lost
