07-14-2021, 07:02 PM   #1
vintage lens compatability
Hi all,
I know that Pentax bodies are designed take legacy lenses but maybe there's a limit? I'm going through old equipment and giving gear to a couple 4-H kids. But I thought I'd hang onto a macro lens I found. It's a Promaster Spectrum 7 28-70mm 2.8-4.2 that I used on a SuperProgram in the 80s. I thought I could mount on the K-3 but I'm not having any success getting it to work and I don't want to break anything. Am I overlooking something, or does the design not apply to 3rd-party lenses?
07-14-2021, 07:10 PM   #2
Aaron28's Avatar
if it worked on the super program it will work on the K-3!! maybe contacts are dirty............
07-14-2021, 07:22 PM   #3
amateur dirt farmer
pepperberry farm's Avatar
when you say that it doesn't work - does it mount on the camera?
if it does mount, are you getting an error message, such as "F---"?
07-14-2021, 07:35 PM   #4
What I mean is, I can't get it to couple.
07-14-2021, 07:51 PM   #5
mattt's Avatar
It would be helpful for the forum to diagnose if you make a photo of the mount and share in this thread.
07-14-2021, 07:56 PM   #6
Interesting, Super Program and K3 are using the same K mount. I never have a problem mounting older K, M, A, F, FA lenses on my K3.
Maybe clean the rear metal part of the lens to remove any dust and or whatever substances might be correcting over years of unused?
07-14-2021, 08:45 PM - 2 Likes   #7
UncleVanya's Avatar
The power zoom contacts may get in way of large shields that some lenses have. A picture of the rear of the lens may help diagnose this.
Vivitar p/k lens not mounting on K-5 - PentaxForums.com
07-14-2021, 08:51 PM - 2 Likes   #8
There are a few old third-party lenses that have a metal bit that gets in the way.
07-14-2021, 09:41 PM - 2 Likes   #9
amateur dirt farmer
the extra long bit that protects the aperture lever - that may be the issue right there....
07-14-2021, 11:09 PM   #10
QuoteOriginally posted by CountryGirl Quote
Couple?
07-15-2021, 12:35 AM - 1 Like   #11
I had the same issue with my Vivitar 70-210 1:4.5 Macro Focusing Zoom, because of its long protection shield of the aperture lever.
Remove the (usually black) shield, trim it down to the size of your other lens shields and assemble it again.
Does the Promaster 28-70mm 2.8-4.2 lens have an A-setting? Manual focus lenses that offer an A-setting, but not a constant aperture for all focal lengths might have slight exposure issues (or at least show the wrong aperture in exif) because they can't communicate to the camera whether they are at f2.8 (@28mm) or at f4.2 (@70mm) (using your lens properties as an example).
07-15-2021, 01:01 AM   #12
35mmfilmfan's Avatar
QuoteOriginally posted by Joe Schmoo Quote
Couple?
I think, in this instance, 'Couple' means 'Mount' - i.e. the camera female mount will not accept the lens male mount.
IOW, it don't fit.
07-15-2021, 03:55 AM   #13
amateur dirt farmer
perhaps a shot of the lens mount itself would help?
07-15-2021, 08:56 AM - 1 Like   #14
jatrax's Avatar
As has been already noted, that lens (if it worked on your Super Program) should work on the K-3. The only reason for it not to mount correctly would be the possibility of an over large aperture shield. That is not common but it does happen on some third party lenses, mostly Sigma in my experience. Actually that should be Vivitar, not Sigma my error. Other thoughts would that the lens has been damaged in some way or that the Promaster is not actually the Pentax version since Promaster would have lenses for other mounts as well.
There are many here that have experience with older lenses and mounts so posting a good picture of the lens mount would help.
07-15-2021, 08:59 AM   #15
QuoteOriginally posted by 35mmfilmfan Quote
IOW, it don't fit.
My, my. I blush!
a-setting, aperture, camera, docs, documents, dslr, free, google, k-3, k-3 ii, k3, lens, lenses, pentax k-3, pm, shield
Lens compatability davy5toes Troubleshooting and Beginner Help 4 06-06-2020 04:20 PM
Vintage-A vs vintage-K Jinnax Pentax SLR Lens Discussion 47 10-05-2015 04:58 PM
Vintage Lens compatability? Uncle Jaque Pentax DSLR Discussion 27 07-27-2015 05:47 PM
Abstract Vintage Camera for Vintage Cruisers jgblodgett Photo Critique 6 01-11-2015 07:21 PM
Thematic Vintage Feelings - Post your vintage shots schnitzer79 Mini-Challenges, Games, and Photo Stories 15 12-02-2014 06:50 AM
All times are GMT -7. The time now is 09:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
