08-20-2021, 04:05 AM   #1
K-3 - Setting the focal length of a full frame lens
OK, so I'm a) not sure how to do this and b) not sure if I need to anyway :-)
When fitting a lens on the K-3 which does not pass data to the camera, and with SR switched on, I have to input the focal length of the lens. No problem with that. But, I have a Sigma 70-300 APO DG, and as that is a full frame lens, on an APS-C camera, technically it acts like a 105-450 lens (I think I have that right?). However, the lens passes it's actual focal length to the camera (i.e. 70-300) and I am not asked to set the length, nor can I if I go in to the menu (that option is greyed out).
The question is, do I need to? If the lens is acting as a 105-450mm, is the SR actually set incorrectly, in that it is stabilising as if it is a 70-300? Or does it not matter?
Any advice on this appreciated, many thanks.
08-20-2021, 04:18 AM - 1 Like   #2
Fogel70's Avatar
It does not matter what format the lens is designed for, focal length of the lens is always the same.
It is only FOV that change between FF and APS-C, focal length on the lens does not change.
So you do not have to care of what focal length the lens communicate to the camera, as it should always be the same no matter what sensor size the camera has.
Just as when you manually input focal length it should always be the actual focal length of the lens.
08-20-2021, 04:24 AM   #3
QuoteOriginally posted by Fogel70 Quote
Great, many thanks for your help :-)
08-21-2021, 12:54 PM   #4
Oldbayrunner's Avatar
Your best bet is to forget that effective focal length garbage for Aps-c. It only effects the field of view which of course makes the subject appear closer even though the lens focal distance remains the same. Where it comes to play in thinking is if your trying to capture a wider field of view then you need to step farther away or change to a different wider lens then if you were using it on a full frame camera.
08-22-2021, 02:07 AM   #5
QuoteOriginally posted by Oldbayrunner Quote
Thank you.
camera, dslr, frame, k-3, k-3 ii, k3, length, lens, pentax k-3, sr
Focal length = focal length, I know . . . . . . . . . . BUT onlineflyer Pentax SLR Lens Discussion 152 08-19-2022 06:04 PM
Manual focus zoom lens Focal length setting Bertminator Pentax K-30 & K-50 11 10-12-2016 12:03 AM
Manual Focal lens length setting stevbike Pentax DSLR Discussion 21 04-02-2013 02:38 AM
setting focal length mc zenitar 16mm 2.8 fisheye lens into pentax k-x jheeno Troubleshooting and Beginner Help 2 01-05-2010 06:31 AM
setting manual lens focal length on K20 boyscout Troubleshooting and Beginner Help 9 05-01-2009 08:55 AM
All times are GMT -7. The time now is 03:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
