Originally posted by maxgroebel A more probable explanation is that the four-way gets hit when the camera is dangling in the strap, or when I pick it up.
Switch strap style? I am a fan of OP/TECH USA cross-body sling straps. I nice big neoprene pad on my left shoulder. If I clip just the right side of the camera body, the camera is always at my right hand and moves smoothly up to my face. If I want to avoid a swinging camera, I use both clips and give the strap length adjuster a tug.
The other thought about 'dangling in the strap', is do you leave your camera turned on between use? To save battery, I nearly always turn the body on (it is ready by the time the body gets to my face) just before I shoot, and turn it off as I am lowering it to the bottom of the sling. I don't even look performing these actions. If you do this and your settings are still off, friend, it isn't the strap causing the issue.
