04-19-2022, 06:45 AM   #1
wbbolin's Avatar
a mysterious k3 af/mf-problem...
hello pentaxians,
have 2 pentax k3-bodies (prestige & silver) w identical firmware 1.43.
both cameras are set up identically.
when switching af/mf on body, one camera (the silver) reacts normally and shows af/mf on backmonitor.
the other one (the prestige) does not show the mf-mode on backmonitor. (see pics)
i hope I could explain my problem.
i've reloaded the firmware in the prestige several times - with no change.
are there any ideas?
thx!
strangely enough, this 2nd body (the prestige) works normally w lenses w an af/mf switch.
Pixel 4a  Photo
Pixel 4a  Photo
Pixel 4a  Photo
Pixel 4a  Photo
Pixel 4a  Photo
Pixel 4a  Photo
Pixel 4a  Photo
Pixel 4a  Photo
Pixel 4a  Photo
04-19-2022, 07:22 AM   #2
As I understand it does the "AF.A" not indicate whether MF or AF is activated, but instead show which AF tracking mode (S-single, C-continuous, A-automatic) is active
04-19-2022, 07:35 AM   #3
Not a Number's Avatar
Does the Prestige go into MF mode even though it says "AF.A" on the screen? Will the shutter release without focus confirmation/lock?
04-19-2022, 07:36 AM   #4
Just checked my K3 with 18-135 attached and switching from AF to MF changes the display accordingly.
If set to AF.A and move the switch to MF, it shows MF.
04-19-2022, 07:39 AM   #5
The AF/MF switch may be faulty. The meter mode switch on my K10D will only go into spot mode if I set it between spot and center-weighted. Try setting the switch between AF and MF.
04-19-2022, 07:45 AM   #6
Fogel70's Avatar
Does the screw-drive shaft retract on the camera lens mount when the switch is set to MF on the non working body?
If not it seems to be a mechanical failure on the switch.
04-19-2022, 09:07 AM   #7
wbbolin's Avatar
ah - manymany thanks for the replies and suggestions so far!
in the af mode the prestige works fine.
in the mf mode the af motor whirrs like a food processor.
1) when using a lens with an af/mf switch, the af works without any problems if the switch on the lens and body is set to af.
2) when using a lens with an af/mf switch, the camera focuses via af if the switch on the lens is set to af and the switch on the body to mf.
seems to be a switch problem on the body.
hargh...
thx folks!
af/mf, af/mf switch, body, dslr, firmware, k-3, k-3 ii, k3, pentax k-3, prestige, silver
Point and Shoot Competition #150 – Mysterious things in and around your home town gbl Pentax Compact Cameras 21 10-03-2020 07:59 AM
Abstract Mysterious Nature Kerrowdown Post Your Photos! 6 05-06-2020 06:33 AM
Help… Mysterious problem and tale of woe with my HD 90mm SGOMMO7 Troubleshooting and Beginner Help 8 05-05-2019 01:12 PM
Mysterious sound from Pentax K3 II body even when not taking pictures dkg2707 Troubleshooting and Beginner Help 9 10-13-2015 09:06 PM
k100d MF/AF toggle switch stuck in MF summatusmentis Pentax DSLR Discussion 9 11-26-2009 03:52 PM
All times are GMT -7. The time now is 08:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
