Originally posted by AfterPentax Mark II Auto ISO is not readily available in Tv and Av, you can see that on the screen. For use with Tv and Av you have to push the green button and on the right side at the bottom you"ll see appear Auto Iso. This is what I must do on my K-3.
Thank you for your advice.
In my case it was different. The screen told me Auto ISO is working but it did not.
The function of the green button can be choosen in another menu item.
Meanwhile I could solve the problem by making a reset in the set-up menu.
The auto-iso function is working again.
---------- Post added 06-04-22 at 03:28 PM ----------
Originally posted by C_Jones In TAV mode, the user sets the shutter and aperture both manually, while the camera automatically figures the ISO. It is in that mode that auto ISO is an objective. You can also adjust the EV (exposure value) while in TAV mode to give the image outcome less or more exposure than is being figured by the camera. If the EV is adjusted while using TAV, the ISO may change to adjust to that setting also.
In TAv mode the Auto ISO function worked properly.
The problem occured in Tv and Av mode.
The Auto ISO function is working even in Tv and Av mode again.
