Originally posted by Chris Hopton I have read many reviews which insists that pixel-shift mode can be used only when the camera is secured to a sturdy tripod. This makes perfect sense to me since I cannot believe that any human being can hold a camera so still as to match a pixel-width in movement as four shots are taken and stitched together. Nevertheless, initially more through accident than design, I have discovered I can take crystal clear street photos in pixel shift mode, handholding the K3II camera, and with shutter speeds at a modest 1/60th of a second and ISO at 100. Yesterday I took 25 handheld high res shots at Orford in Suffolk and every one of them was sharp and detailed although one (of the cemetery) did show on the JPEG image some downward motion blur (which was not at all apparent in the DNG composite shot). I've now emailed RICOH to ask them how this is possible. Have they undersold the K3II's full potential? The weather yesterday at Orford was also quite blustery which should have compounded the problem of getting any usable shots.
I have failed to find any support on the web for handholding the camera for pixel-shift: everybody rules it out as an impossibility if you want to avoid "zipper artefacts". I wouldn't believe it either if I hadn't seen firsthand the results in DXO Labs of the DNGs produced by my K3II with the 31mm limited edition lens.
I'd attach samples if the file sizes were not so restricted.
Has anybody else had success with handholding the camera whilst using pixel-shift mode?
I would be interested for you to compare them in Raw Therapee -- that is to look at an individual frame of the four captured with a pixel shift burst followed by looking at the combination of the four with motion correction and then finally to look at the motion mask for the combined image.
I think there is a strong placebo effect with pixel shift images. We think we should see a difference and so we do, but the reality is that, even with the scene is still and the camera is on a tripod, there is little difference between a single shot capture and the pixel shift image. You have to push shadows and do a lot of sharpening in order to really perceive a difference.
I don't own a K-3 II, but my experience with the K-1, K-1 II and K-3 III used with Raw Therapee is that pixel shift isn't very effective (if at all) hand held.
