Originally posted by btnapa Nice work. I know a little bit about Gigapan but never used it. How long did it take the computer to complete the task from start to the final image?
What was the ISO on K3?
Thanks
The time to stitch the panorama depends on many things, such as the number of cores in your computer, the mp size of each image, the type of stitching software, and the number of images. Gigpan Stitch is fairly basic and fast, because it does not perform anti-ghosting.
If you read the "Stitcher Notes" on the side panel, this example took less than an hour: Total time 37:38 (11 seconds per picture) Alignment: 4:42, Projection: 8:52, Blending: 24:04(Preview finished in 18:09.)
The "Stitcher Notes" also show the ISO was 400.
The "Stitcher Notes" are scraped from the metadata of the images and automatically uploaded with the panoramic image if you use Gigapans' own stitching software (you have the option to not upload if you wish).
As a comparison, here is the largest one I have ever taken, with a K-5, took almost 19 hours to stitch (on a different laptop):
Cusco from Mirador Monumento el Gran Inka Pachakuteq
You cant expect too much clarity on an old manual focus lens like I used, and also due to atmospheric haze from the ocean, heat shimmer, and f/8 on the crop factor K-3 is equivalent to f/12.. But I am happy with the result except for the vignetting. Gigapan Stitch EFX contains anti-vignetting as an option but it was still visible in this image. Made worse by me increasing contrast with Photomatix.
---------- Post added 8th Apr 2023 at 01:43 AM ----------
Originally posted by EssJayEff I bought my K-01 specifically to use with a Gigapan because its small size and weight meant it could be used on the base model for a lower price than the midrange model. Then I discovered I had free access to one, so I gave it try. I only used it on one outing, with okay results for using it only once. I headed in a different direction, however, with my photography and never revisited the device. This was back in 2014 . . . so I just sent an email to the person who helped coordinate my access to it then to see if it is still available. It's a holiday weekend, so we'll see what develops. Yup, could be another rabbit hole!
I also have the midrange model, the Epic 100. It could handle my K-5 with Tamron 300 zoom no problem at all, as long as you kept some spare AA batteries at hand. The midrange model has had a bit of a renaissance lately with super zoom bridge cameras, due to their light weight. The mid-range model also has cable shutter option for Canon & Pentax cameras, which is a handy bonus!
The thing with this type of panoramic photography is you are limited by the weather (clouds, rain, wind, all play havoc), power supply, and suitable vistas are not in everyone's backyard. Also, large gigapans can wear out your shutter pretty quick, when a single shoot can eat up thousands or even tens of thousands of images. But that challenge is what I like!
