I have two K3 bodies and I know they are both almost 10 years old, but I have a curious problem with both. Using two different lens the Pentax 18-270 and the Pentax 55-300 PLM (latest version) both exhibit the problem of focussing from near to far which is most noticeable at the long end of the focal range. For example if I have the 18-270 at 270 and focus on something quite close it's OK, not quick but good enough. I then move the camera to focus on a far away say 70 yards and it will not focus, even if I press the shutter button again, it usually should automatically refocus in AF-C mode. OK so I tried it in AF-S mode and same happens, I have to press the shutter button several times and then it will refocus. Same happens on the 55-300 using both K3 bodies, although in live view mode it is much better on both. It's like the the focussing has lost its sensitivity.
To try and work out if it is the lens or camera I used my K3 III body with both lens and each works perfectly and quite quickly which I would expect. So it isn't the lens.
So I wonder if I have changed something in the settings for the K3's, although I don't remember this happening recently. Both cameras have fully charged batteries and the latest firmware, I also cleaned the contacts. Using the AF back button exhibits the same behaviour.
Any ideas esteemed forumites, as I would hate to think that both K3's have the exact same problem.
Thanks
Tim
