10-10-2013, 01:26 AM   #166
falconeye's Avatar
QuoteOriginally posted by fuent104 Quote
Global shutter, the opposite of rolling shutter, is desireable
for video, yes (global electronic shutter, as opposed to rolling electronic shutter).
However, most possible analog implementations of a global electronic shutter (charge buffers) have a negative impact on image quality, be it read noise or full well capacity. Digital implementations could avoid that but don't exist and would be very expensive, esp. with high pixel counts.
The jello effect is reduced by faster readout speeds and I expect that with increasing sensor speeds (I hear of 1080p@120Hz sensors and 4k video coming soon) the jello effect will become small enough to lift the pressure to make a global shutter. It is kind of a race and it remains to be seen if a global electronic shutter will ever come to a still camera.
Note that the K-3's mechanical shutter is a rolling shutter too (corresponds to 4000p@180Hz) and nobody ever complained about its rolling shutter effect in stills...
10-10-2013, 01:47 AM   #167
It is quite reasonable to expect that they would not use the exact same menu name to mean two different things, Falk.
I just assume Pentax not to expect a user to compare user manuals..
Many of us here own more than one Pentax camera, to my mind that's exactly what users will do and Pentax would certainly be careful in keeping things standardised across models. It just makes sense.
10-10-2013, 03:02 AM   #168
falconeye's Avatar
QuoteOriginally posted by sledger Quote
Yes, if things were different.
But both menu items designate stabilization during video. It is just not meaningful to deduce implementation from this.
It is like saying: the K50 has a burst mode menu item, so the K-3's burst mode must be same speed as K50 because they named it the same. It simply isn't a possible deduction. Same for "Movie SR".
10-10-2013, 03:10 AM   #169
gazonk's Avatar
It is a separate setting from SR on/off during stills, hence the different menu item name to avoid user confusion.
- which is a good idea, so the user knows that (s)he is only affecting movie SR when changing the setting here. I don't think "Movie SR" means a specific implementation in "Pentax lingo". My 7 year old (and still waterproof ) Optio W10 has the "cheap" electronic variant, and Pentax called it "Movie anti-shake" back then.
10-10-2013, 03:23 AM   #170
Fogel70's Avatar
On DSLR using sensor stabilization for video they call SR for "Shake Reduction" for both photography and video, but on cameras using digital SR for video they only use "Shake Reduction" for photography and "Video SR" for video.
So at least so far they have used a separate name for "digital SR".
10-10-2013, 03:24 AM   #171
It's quite visible if you're trying to freeze the movement of some objects with a shutter instead of short duration flash. Not only in Pentax cameras of course.
10-10-2013, 03:54 AM   #172
gazonk's Avatar
Well, a couple of years ago my son asked me what happened to the walls of the houses he shot with his iPhone 3G out of the window of a train :-)
10-10-2013, 04:27 AM   #173
the best part is hat i was ready to by a gh2 or 3 for video but seems that the k3 will be a great video camera...we must wait for an hack like gh2 to have the best anyway.
10-10-2013, 05:19 AM   #174
falconeye's Avatar
QuoteOriginally posted by gazonk Quote
The little word "its" in the quoted text referred to a focal plane shutter. The iPhones have no such shutter.
10-10-2013, 05:34 AM   #175
It doesn't matter, the regular FP shutter gives you the same results with objects moving fast enough.
10-10-2013, 09:58 AM   #176
falconeye's Avatar
QuoteOriginally posted by jaad75 Quote
Post makes no sense when reading my posts again.
10-10-2013, 10:41 AM   #177
johnmflores's Avatar
At this point I think that all we can do is wait for some video-oriented testers to get their hands on the K-3 and really put it through its paces.
10-10-2013, 11:30 AM   #178
Lens Buying Addict
monochrome's Avatar
Q/K-01/K-30/K-50 are the limited, different, mid range Menu set and control dial / button set. K-3/K-5/II is the full-featured Menu and Contol Dial set. It is natural to expect definitional and operational changes from the Mid-range Menu to the Full-Feature Menu.
10-10-2013, 03:36 PM   #179
falconeye's Avatar
Anybody saw this? ->
It says twice the buffer size and 5x readout (14 Bit data transfer) speed.
If they make use of this 5x speed improvement when grabbing frames, assuming the same subsampling layout, then the jello effect could be reduced to 30% of that of the K-5. Theoretically. Maybe, this picture is wrong if it refers to the Milbeaut chip and the sensor itself is the bottleneck.
10-10-2013, 03:58 PM   #180
There is an English version of it and it says 5x transfer speed and 2x buffer capacity. Animation clearly suggest that it is about processor- buffer transfer, not sensor readout speed.
dslr, k-3, k3, mode, modes, pentax, pentax k-3, switch, video
Now that official K-3 specs are released, how good for video? jake14mw Video and Pentax HDSLRs 20 10-14-2013 12:56 PM
Pentax Optio WG-3 video download challenge Eric Z. Troubleshooting and Beginner Help 2 09-06-2013 06:33 PM
With HDMI out & 3.5mm stereo mic in the K-01 is better than the K-30 for video jogiba Pentax K-01 2 05-22-2012 01:52 PM
Spot one! robertstech.com discussion on K-01 hcc Pentax K-01 18 02-08-2012 07:22 AM
Short Movie - Robot Warriors + Discussion on DSLR for Video tiny Video and Pentax HDSLRs 2 06-21-2010 12:29 PM
All times are GMT -7. The time now is 11:43 PM. | See also: NikonForums.com, part of our network of photo forums!
