11-03-2013, 04:59 AM   #331
silent and snappy AF in video as well as peaking, are all requirements for this supporting role.
Definitely not AF. Especially "snappy" AF.
11-03-2013, 07:47 AM   #332
falconeye's Avatar
Do you have any idea why they may have went backwards compared to the SR implementation on the K-5?
There are many possible causes, e.g., management, software engineering team fluctuation, and one technical reason:
If they made the margins smaller, the max. amount the sensor is allowed to travel. Still image stabilization does not require as much margin as the K-5 has had.
However, I hear that LV still behaves as it did before, i.e., stabilizes the LV image. So, I don't know really.
11-03-2013, 07:48 AM   #333
The only reasons I can think of are
  • quieter operation, and
  • increasing battery life.
I agree, it's strange that they would disable a K-5 feature for quieter operation and increase battery life.
External mic and a spare battery is not a big issue. And if it's an issue for some, then make Digital and Mechanical stabilization an option in the menu.
Of course we're just speculating here.
11-03-2013, 08:18 AM   #334
johnmflores's Avatar
K-3 will not be used for commercial video.
Video is a supporting role for dSLRs (except maybe the four cameras which are selected by commercial film makers). Supporting role as in family videos, event coverage, social media content. Where people don't bring their rigs, rails and focus pullers.
So, decent control over jello effect and sampling artefacts, decent stabilization, silent and snappy AF in video as well as peaking, are all requirements for this supporting role.
Of course, K-3 can still shine for its major role, photography
AFAIK, nobody's managed to implement silent and snappy video AF on any camera with a sensor larger than Micro Four Thirds, mirrorless or otherwise. I haven't used Sony though, so YMMV. Some are better than others, but they all feel generations behind what we are used to for stills. Dedicated video cameras, even the consumer level, do a much better job, likely because their smaller sensors give them a much greater margin for error.
And I'll that we'll have to wait and see more samples, but my experience with the K-01's and Q's digital stabilization is that it is "decent". Sure, there are situations where it can be tripped up, but if we are shooting home videos instead of Hollywood blockbusters, then it may very well be up to the task.
11-03-2013, 08:36 AM - 1 Like   #335
The K-01 stabilization was turned off on my camera on day 3 of testing.
Digital stabilization is not that old of a technology and it's still being refined. I'm sure in 5 years time, it will be amazing.
For home movies, I prefer the jerky unstabilized video vs the digital stabilized video. The unstabilized looks more like my old Super 8.
11-03-2013, 03:58 PM   #336
Class A's Avatar
Yes, makes sense.
The potential technical reason could be construed to fuel FF dreams by the hopeful.
11-03-2013, 04:13 PM   #337
Just a question to those that own the K-01 and/or K30.
When you deactivate SR in video mode, does the image return to a non-cropped field of view or does it stay partially cropped but not stabilise?
11-03-2013, 04:30 PM   #338
falconeye's Avatar
QuoteOriginally posted by johnmflores Quote
The 70D is great at this, professional grade focus pull quality. A few others are good enough for home use IMHO.
11-03-2013, 06:39 PM   #339
The fact that the 70D is the only one that meets this criteria demonstrates that this is a non-trivial achievement. Congrats to Canon for cracking the code. To be honest, I'm not surprised that Pentax is behind the curve here, especially since they don't have the resources like Canon and Nikon to put PDAF on the sensor but rather have to wait for their supplier (Sony) to get to it themselves. IIRC, one of the later SONY NEX camera had PDAF on the sensor and it wasn't very good.
I suspect that people that are expecting more are underestimating the technical challenge.
11-04-2013, 12:37 PM   #340
QuoteOriginally posted by Bolt Quote
Stays cropped and not stabilized.
I can't see any reasons why pentax would crop the image even when it's not stabilized. Stupid.
11-04-2013, 02:06 PM   #341
QuoteOriginally posted by JohnnyXD Quote
ok, but lets be fair. the crop isn't that much. Personally i hardly notice it & on my 16-45 lens, wideangle is still a wideangle...
My sony has the same issue where the crop is even bigger, so i guess there might be a good reason.
At least, it does not really bother me. but i am not everyone ofcourse
11-04-2013, 03:01 PM   #342
I believe you're correct regarding autofocus being a very technical problem and the fact that it doesn't have PDAF on the sensor makes it very difficult. Software only solutions may never work for smooth autofocus to rival a camcorder or the new 70D.
Saying that, mechanical sensor stabilization exist on the K-5 and doesn't exist on the K-3. I hope the issue isn't related to a physical limitations in the SR unit or licensing. I'm still hopful that it will be added in a future firmware upgrade.
11-04-2013, 03:22 PM   #343
AFAIK it has to do with keeping an integer (or at least half integer) scaling factor between the sensor and the recorded video.
Full HD is 1920 pixels wide whereas the K3 sensor is 6016. With a 1:3 ratio, that is 3 horizontal pixels per one horizontal pixel in video makes 5760 pixels, which is about 95% of the width.
With the K-30 you have 4928 hoirizontal pixels so the closest is 1:2.5, giving 4800 pixels, being about 97%.
To get the full frame you would need to scale some odd ratio. For the K-3 that would be 3.13333. Although it can be done it takes far more processing to do and especially if you want to avoid alisasing artifacts.
All digital cameras I've ever had crop the video to a greater or lesser extent, even the ones without image stabilisation, most likely for this very reason.
11-04-2013, 04:04 PM   #344
QuoteOriginally posted by lister6520 Quote
hm, interesting. digital stabilizing might thus not even be related to it
Although i thought i understood my sony A77 crops to be able to have an area to play with for SR
I do think the crop is far less (even never noticed) on a canon.
Maybe the answer is a mixture between the two?
thks
11-04-2013, 04:30 PM   #345
I'm a bit disappointed about K-3 after feedbacks from first K-3 users about the video functions .
It's not better than even GH2 (hacked) or near matched to Pana GH3 !
For years, I always hope Pentax to give some video tech breakthrough , so I won't have to carry both cameras all the time.
dslr, k-3, k3, mode, modes, pentax, pentax k-3, switch, video
Now that official K-3 specs are released, how good for video? jake14mw Video and Pentax HDSLRs 20 10-14-2013 12:56 PM
Pentax Optio WG-3 video download challenge Eric Z. Troubleshooting and Beginner Help 2 09-06-2013 06:33 PM
With HDMI out & 3.5mm stereo mic in the K-01 is better than the K-30 for video jogiba Pentax K-01 2 05-22-2012 01:52 PM
Spot one! robertstech.com discussion on K-01 hcc Pentax K-01 18 02-08-2012 07:22 AM
Short Movie - Robot Warriors + Discussion on DSLR for Video tiny Video and Pentax HDSLRs 2 06-21-2010 12:29 PM
All times are GMT -7. The time now is 05:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
